Author Topic: Marlin Crawler High Steer kit vs. 3" lift  (Read 6252 times)
hiltu
  • Member since Jan '10
« on: Jan 24, 2010, 06:45:33 PM »
Hey everyone, this is my first post but ive been on yotatech for about 2 months. Anywho i have an 85 4runner (22re, 5speed, 3" rough country lift with 33" procomps) and really want to get a high steer kit. My options are all-pro offroad, trail gear, and marlin crawler. Im trying to go all marlin crawler for my offroad needs, however im reading a concern about running less than a 4" lift. Im trying to avoid lifting it any higher at all costs as my current setup works and i have confidence in it. I would rather trim fenders. So im looking for some examples of 3" or less of lift with the high-steer kit, all brands are applicable. Thanks guys
toyomr285
  • Male Posts: 227
  • Member since Jan '09
Re: Marlin Crawler High Steer kit vs. 3" lift
« Reply #1 on: Jan 24, 2010, 07:46:59 PM »
I was told that you can run high-steer on a 3 in lift.  By the way, what is the width size on your 33's and did you put 4.88 and did you upgrade your birfields?
85_4RNR
  • Turtle Points: -23
  • Male Posts: 265
  • Member since Nov '09
« Reply #2 on: Jan 24, 2010, 08:06:48 PM »
if you have future plans of gettin better leafs for example marlin leaf springs, do hysteer then. if you did hysteer right now with rough country leafs and then in the future decided to do leaf springs that move your axle forward, which is what you want, you would have to move your steering box more forward so as to not have tie rod/drag link clearance issues.
 :thumbs:
I work a 2000 BMW 540i 6 speed
8D3TOY
  • Turtle Points: 5
  • Member since May '05
« Reply #3 on: Jan 24, 2010, 08:18:34 PM »
http://board.marlincrawler.com/index.php?topic=65878.30
Reply #34 he has a similiar situation, high steer with Pro comp 6" replaced with TG springs.  He discovered he did not have to move his steering box forward after all.  If you have any questions PM Hilux-1983 hes a cool dude and will be happy to help you.  Searching will bring up more than you ever wanted to know about high steer.  Good luck.
hiltu [OP]
« Reply #4 on: Jan 24, 2010, 08:34:51 PM »
they're 12.50's still have stock gears but im going to make a big purchase and im going with a ratchet locker rear and debating on a LSD for the front, also i wanna go 5.29's. I plan to get skinny 34s or 35s AKA pizza cutters. Looking at the 30 spline longfields for birfs.
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
« Reply #5 on: Jan 24, 2010, 08:36:11 PM »
He used Allpro springs. :yupyup:
hiltu [OP]
« Reply #6 on: Jan 24, 2010, 09:57:51 PM »
all-pro not a good brand? i've been seeing some disses about them
85_4RNR
  • Male Posts: 265
« Reply #7 on: Jan 25, 2010, 05:45:26 AM »
All pros are good leafs but TGs are garbage.
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
« Reply #8 on: Jan 25, 2010, 10:29:39 AM »
X2! I have 5in Allpro springs for 3 years now that are still good as new and they ride great.
proof?
hiltu [OP]
« Reply #9 on: Jan 25, 2010, 12:28:32 PM »
i've heard them be refered to as "all-pooh" on some threads. I believe it was on yotatech though.
hiltu [OP]
« Reply #10 on: Jan 25, 2010, 12:30:58 PM »
 :thumbs:
can't this all be avoided by initially installing the IFS pump really far forward on the frame? Or is this a disadvantage having it too far forward?
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #11 on: Jan 25, 2010, 03:23:53 PM »
THe "pump" doesn't get installed on the frame - that part is on the motor.  You want to install the IFS gearbox on the frame for hysteer.  From what I've seen and heard, I see no dissadvantages to mouting your gearbox as far forward as possible.  You just need to make sure that your pitman arm/tierod ends to frame and spring clearances are good.
I cut out a small section of the double wall portion on my radiator core support and then hammered what was left to make more room to move my steering box as far forward as possible on my 2nd gen.  I'm running Marlin's 4" kit with front hangar and have no steering clearance issues.  I will be setting up my bumpstops accordingly though.
hiltu [OP]
« Reply #12 on: Jan 25, 2010, 05:07:51 PM »
my bad, i meant IFS steering box
drew303
« Reply #13 on: Jan 26, 2010, 02:08:17 AM »
Why do TG's spring suck? I've seen all brands run and I can't say ones better than another. IME been hit and miss.
As for hysteer and stuff, I run TG 3" personally and my buddy runs his own custom front packs with even less lift, we both rock hysteer. It doesnt matter what springs you run, you can still use hysteer, the only downfall to running less than 3" of lift is you dramatically limit your uptravel which is limited by running hysteer in the first place. But on that note, you dont want to go negative on the springs anyway so it doesnt matter. When they hit level there's room for the links.
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
85_4RNR
  • Male Posts: 265
8D3TOY
  • Turtle Points: 5
« Reply #16 on: Jan 26, 2010, 11:31:17 AM »
MY bad AllPro
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
hiltu [OP]
« Reply #18 on: Jan 26, 2010, 03:34:01 PM »
thanks for the link, studentwheeler
GRM
  • Member since Dec '03
    • Website
« Reply #19 on: Jan 29, 2010, 09:37:32 PM »
I run 1.5" lift springs. Everything cleared with a flat pitman arm.
As for what springs to run... I have had VERY VERY poor experience with buying components from ANY vendor unless its some desert race shop, a very basic fab shop (like a spring hanger) or MARLIN!
If you want your :pokinit: to run for 100k miles... buy everything marlin sells. If you need something else, buy the part from Toyota.
If you want your :pokinit: to run for 3k miles... buy some other brand.
Trust me... I've done this... convinced myself that since I never heard of a problem online that the parts were fine. Guess what... the parts broke.
Buy marlin parts.
Last post Jan 21, 2007, 05:43:01 PM
by Nothingface5384
Last post Apr 13, 2007, 10:47:57 PM
by kneedownnate
No lift high steer
Last post Jun 15, 2010, 10:13:26 PM
by jrock
Last post Mar 01, 2011, 08:17:41 PM
by Orange 4Runner
Last post Aug 09, 2013, 03:18:10 PM
by Shamb
