Author Topic: ARB/ high pinion/ longfield axles..help  (Read 2508 times)
sprduper
  • Member since Nov '08
« on: Jan 14, 2010, 02:10:57 PM »
Hello all,
I recently installed a High pinion with ARB and longfield 30 spline axles w/hub gears. After the install i noticed I couldnt turn the sterring wheel in one (either left or right) direction with ARB activated with both hubs locked. Feels like steering is binding. Once I unlock either left or right hub, the steering is fine. I dont have to drive the truck for this to happen. The inner housing has been clearanced for the axles. Im stumped..any help is appreciated. I can turn the hubs from lock to unlock with with no problems.
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
Re: ARB/ high pinion/ longfield axles..help
« Reply #1 on: Jan 14, 2010, 02:30:23 PM »
 :twocents: The birfields bind when the ARB (or any front third)is spooled or welded. Not being able to turn because of that is normal. Your stock steering box is not strong enough to turn the binding birf's. I know because i asked the same question when my front diff was welded. Now I have an ARB too. just turn it off if you wanna turn, sometimes you have to roll around a bit after unlocked the diff to get the birf's to unbind. One thing you could do is add Hydro Assist the ram should be strong enough to turn even with the ARB locked. That is what im workin on right now.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
sprduper [OP]
« Reply #2 on: Jan 14, 2010, 02:41:03 PM »
thanks for the info. would it bind even if the truck isnt rolling/moving yet?
potter85
  • Male Posts: 257
  • Member since May '09
  • complete disregard for sheet metal.....
« Reply #3 on: Jan 14, 2010, 02:53:31 PM »
any truck that is locked in the front doesnt turn, just how it is
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
swapped89
  • Male Posts: 1,221
« Reply #4 on: Jan 14, 2010, 04:41:11 PM »
YEP, i have found that if you really wanna turn while its locked you can roll back and forth until it turns but there is really no point in doing that.
sprduper [OP]
« Reply #5 on: Jan 14, 2010, 09:05:50 PM »
got it...looks like it will be a challenge to drive on the rocks..for me atleast.  I had an EZ locker in the front before so steering was still ok. I suppose I have to turn off the ARB, steer in intended direction, turn on the ARB and drive?..any pointers?...thanks.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #6 on: Jan 14, 2010, 09:22:15 PM »
Install hydro assist.
I run with my ARB turn on all the time, but I have full hydro but I even did it when I had hydro assist.
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Member since Sep '05
  • Do You Know A Sweeney Bro?
« Reply #7 on: Jan 14, 2010, 09:52:39 PM »
yeah you can switch it off when you turn, that will help tremendously and it will also put less stress on the axle shafts.  That and hydro assist are the only things you can do
97 4runner Limited
Last post Dec 19, 2002, 04:35:25 AM
by trt2
Last post Mar 31, 2005, 10:39:18 PM
by jr9162
Last post Jul 16, 2006, 10:41:36 PM
by 4runner DUDE!
Last post Feb 27, 2008, 08:45:31 AM
by robrub00
Last post Apr 18, 2014, 06:53:48 AM
by floorrunner
