sounds good. how are you liking the spring? and what did you get?
I took 2 of those female splines and cut on and welded it to the other and made a longer driveshaft for the front on my truck now I just need to do the same with the male splines
Hell Just finish burning it in and run it like that. What could go wrong?
Heck, your only seeing half of what was built. The other half of the angle iron is on the I-10 somewhere when in let go. I'll try it again and see what happens:) By the way, I've got one heck of a vibration in 4wd now:(
Its about time you make your own front shaft. Get that thing down here so we can wheel.
Eager to see how you turn out with the drive line. I have a 5 inch lift setup coming from Trail Gear. The setup is for a 1983.
hey rob i saw you driving on i 10 on wednesday. the truck looks awesome. keep up the good work.
Started by toyota35bogger Parts Wanted
Started by locktup Parts For Sale
Started by Lonestar Honcho Parts Wanted
Started by lbhsbz Parts Wanted
Started by the_white_shadow Parts For Sale
