Marlin Crawler Formula Toyota Buildup
Started by Marketing, November 19, 2004, 09:37:29 PM
dirtbag
Quote from: crawlingturtle on February 22, 2005, 07:46:48 PM
Hey Marlin Crawler, if I ever make it out to California, can I get a ride in the Buggy?  :hyper:
ummmmmm................ :idea:  :smack:
they ARE in California  :joke:  :hahaha:  :laugh:
Don't worry, ct, it's all good  :beerchug:
crawlingturtle
#211
I said If "I" ever make it out to California.  Reread the post. Also, FYI I live in Colorado.   :psss:    :hammerhead:
The EVIL TURTLES are taking over!!!
Marketing
Quote from: MidgetMike on February 21, 2005, 09:49:51 PM
I noticed that most of the other formula's move the engine and driver back more, I know that you all at Marlin have a little bit of a plan scheming I am wondering what it is. Why didn't you move every thing back as far as every one else. Not judging just wondering?Love the short throw, I am pretty sure that you guy's like the L52 for the extra bell housing strength with more than a dual ultimate, any other reason?
Today I got to sit in the truck with all the control and shifters in place. It's really coming together. The tcase is really high up inside. Even with short shifters on the tranny and tcase the shifters are up higher. It's a bit of a maze to get to the dash. We may look at moving the switches back to between the seats.
As for the driver position.  It's been long held as fact that you want more weight on the front for climbing. When your climbing much of the weight shifts to the rear so it can be hard to get traction on the front when it's up hill. When "Tiny" the Nelson built buggy was being built there was a real concern that it was not going to climb well due to more weight being in the rear due to it's rear engine design.
Tiny has just about a 50/50 weight split front to rear. Tiny's outstanding performance in competition has some thinking that it's better to have more weight in the rear than previously thought. Personally I think there are other advantages to the design of Tiny that allowed it to do so well. I think the weight distribution of this design is a disadvantage but having the driver forward was a high advantage.
Communication between driver and spotter is hard. Even with the best driver and spotter in the world it's hard to communicate, even if you can hear each other with headsets. Driver and spotter often see much different views of thing from their perspective. Placing the driver literally on the front axle puts the driver where he can see a lot more of what is in front of him. I spotted for Tiny each of three events that lead up to it's first series win at CRCA. Spotting for Tiny is different than other trucks in that your looking for different things. On a normal truck, the driver can see the outside of left tire but can't see the right side tires much at all. In Tiny the driver can see the inside of both tires but can't see anything on the outside of the tires because your sitting between the tires. View to the rear is ok, but the view to the front is like watching a widescreen TV. In building Tiny everything possible was done to keep weight as far forward as possible, including running huge amounts of water in the front tires.
If we were building the this truck from scratch we will be leaving the motor in the stock position and not moving it back at all. We would change the shape cage to put the driver even further forward. We ended up splitting the difference and only moving the motor back 1/2 the way it was designed for. Also if we were only building for competition we would have made it much smaller, but then it would not be as practical for trail use. We really like the dual purpose this class offers.
Just to sum it up. I prefer weight and driver to be as forward as practical.
Marketing
#213
Most of the frame for the floor was installed today using 1 X 1 square tubing. The floor aluminum will be laid over the frame.
Marketing
Seat mounts are added to the frame for the slide rails to bolt to...
dirtbag
Quote from: crawlingturtle on February 22, 2005, 08:14:38 PM
sorry, my FUBAR  :smack:
gmrwizard
Your posts are way cool. They give us food for thought along with good tech. The pics are great keep them coming. I was in the shop yesterday and got to see it first hand,
IT IS AWESOME
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Doing 88 Toyota 4X4 (Desert race truck)
Next 81 Toyota 4x4 (drive train upgrade)
MiniSimp
You should use a push button start and put the button behind the twin stick. :bling:
Marketing
The EFI system came in from LC engineering today. Just over $1000 delivered with the optional idle up system.
freds40
That is a ton of cash to get the motor going but from what I hear, that system is the hot ticket for wiring an RE in a buggy.
"between projects"
FATB0Y
Quote from: Chris Geiger on February 23, 2005, 10:00:22 PM
That looks cool what all can ya do w/ it? Besides run the Fuel Injection
donkeykong
What is the product number on that fuel cell from summit.  I am looking for a a bigger tank, and want to explore all my options. Is that a off-road application only or will it work on a street drive truck
Marketing
Quote
It is a much simpler EFI system. It allows adjustment and programming via an included remote control. It also allows the diver to and just the mixture on the fly.  It uses a map sensor so there is no need for the stock air flow meter.
Marketing
#223
The battery tray is going to be on top of the transmission and behind the dash.
Marketing
KYOTA
Sheesh you guys arent done with that thing yet? whats taking so long :talkingn: kidding of course looking awesome as usual !!  :turtle:
Marketing
#226
Rocky is making progress on the installing the EFI system. Last night after work he hooked up most of the system and created a mount for the computer under the dash.
Instead of an air flow meter this system uses a MAP sensor. This sensor installs in the intake plenum.
Photo of the indash mixture control.
scheid6996
Its a redneck thing
"Nobody Loves Me"
TrackVino
MUDJUNKY
"I avoid myspace like the devil himself...  Nothing good can come from having teenyboppers and childmolesters mixed with emo morons hanging out in one place...." white trash.
MiniSimp
stone4x4
GOD MADE DIRT AND DIRT DON'T HURT
MiniSimp
Are you swiss cheesing for weight reduction? Or was the battery tray made from scrap?
Marketing
Quote from: MiniSimp on February 27, 2005, 09:54:04 PM
Does the engine have to be smog legal?
No smog controls required but, it is required to have a muffler.
reklund5
What, no cold start injector? :gap:   I assume you can richen up the mixture when cold to compensate?  Does that EFI system have any Datalogging capability?  Can you custom setup the mapping?    Looking great, keep up the good work
Ryan
Northern Runner
So does this mean that Marlin will possibly start producing complete "turn key buggies"???? :wag:
Marketing
 We are putting a lot of after hours time into this because we want to see it built. A truck like this would retail for about $35,000. I don't think poeple are willing to pay that much.  We are only a 3000 sq ft shop and can't building there. Hell we are having problems delivering just the parts people are ordering. As we grow, we would could consider building finished rigs in the future, but not right now.
mudaddict
That is a awsome build guys keep up the awsome work! :thumbs:
I work At
All Pro Off Road
FATB0Y
