Author Topic: Questions please answer  (Read 1528 times)
alex225
  • Member since Nov '04
« on: Nov 19, 2004, 06:50:29 PM »
I have a 94 toyota pickup what is the backspacing on my current set of wheels? and I want to run 32 but have no lift what backspacing do I need to do this also what rims size? Thank you for your time
GrimReaper
  • Turtle Points: 58
  • Member since Aug '04
Re: Questions please answer
« Reply #1 on: Nov 19, 2004, 09:02:09 PM »
I have a 94 Toyota pickup what is the backspacing on my current set of wheels? and I want to run 32 but have no lift what backspacing do I need to do this also what rims size? Thank you for your time
Ohhhhhhmmmmmmm
Ohhhhhhhmmmmmmmm
Ohhhhhhhmmmm
Not getting anything, sorry.
Take the wheel off. Lay a straight piece of something across the the tire. Measure down to the bead and write that down.
 Now measure down the the wheel mounting surface where the lugs go though. Subtract the first measurement and you got your back set within a couple mm.
Don't have an answer on what will fit the 94. I'm told 32's on stock rims is no problem on my 86 with a 2 inch body.
blyota91
  • Male Posts: 170
  • Member since Sep '04
« Reply #2 on: Nov 20, 2004, 04:20:23 AM »
I don't have any dimensions for it but I do have this which will make measuring and figuring it out easier.
http://www.eaglewheels.com/wheelsection.htm
Retiring the 91
Rebuilding the 94
HFCRAOffroading
  • Turtle Points: 425
  • Member since May '03
  • I love Marlin Crawler!
« Reply #3 on: Nov 20, 2004, 10:09:23 AM »
 Stock rims for that year are 4.75 back spaced.
 3.75 back spacing should be good for 32's.  You may have to hammer the fender seam flat to keep them from rubbing.
    Hope this helps!
         Jack
Last post Apr 01, 2005, 02:42:19 PM
by stealthrunner
Last post Oct 19, 2005, 01:12:06 AM
by Cheesemaker
Last post Aug 10, 2009, 08:59:06 PM
by kneedownnate
Last post Dec 02, 2009, 11:52:22 AM
by 85toyrunner_rockrig
Last post Dec 03, 2014, 02:00:41 PM
by buddyb911
