Author Topic: IROK RADIAL VS. BIAS  (Read 17633 times)
SLIVER
  • Male Posts: 503
  • Member since May '06
  • ))--SLIVER-->
« on: Dec 14, 2009, 12:03:23 AM »
LOOKING AT THE 37"
RADIAL 37X12.50X15
BIAS 37X14.00X15
Are the bias more aggressive???
Which one would you get if you were faced with the decision??
Thanks
))--SLIVER-->
))--SLIVER-->
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
Re: IROK RADIAL VS. BIAS
« Reply #1 on: Dec 14, 2009, 12:07:53 AM »
i read on super swampers web site that the 36 irok is actually bigger than the 37
http://www.intercotire.com/tires.php?id=6&g=1
if you look at OD, the 36 is taller
bias is a softer compound that airs down really well and sticks, but they dont last long on the road at all.
radial is a harder compund that lasts on the road better but not much better than the bias irok...
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #2 on: Dec 14, 2009, 12:25:14 AM »
good thread. im on my second set of iroks, first 37s now 39.5s and both have been radial. i love them, but i hear ALOT of different things about bias. i wanna know more about the difference
UA 342
STEAMFITTERS
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
« Reply #3 on: Dec 14, 2009, 12:38:29 AM »
Which tread are more aggressive??
Or are they the same?
EDIT: Nevermind, on that link they say that the tread is 21/32 on boh radial and bias.
The radial is 13.50 wide and the bias is 14.71 if I remember right.
I like the idea of a 13.5 over and almost 15" wide tire.
))--SLIVER-->
« Last Edit: Dec 14, 2009, 12:45:09 AM by SLIVER »
))--SLIVER-->
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
« Reply #4 on: Dec 14, 2009, 12:47:24 AM »
What size is Marlin rockin? His truck looks real good with IROK's on!
))--SLIVER-->
))--SLIVER-->
peacesells
  • Turtle Points: -17
  • Male Posts: 791
  • Member since Jul '08
  • motley lou
« Reply #5 on: Dec 14, 2009, 01:16:36 AM »
I ran the bias 39.5's on 15x10 beadlocks. I would be at 2-3 pounds in front with 130lbs of water in each and 4psi in the rear, and I had a lot of mixed feelings. For one, with 10in wheels these tires are BALLOONS! second, they measured out at 36.5in when aired down, third, in order to get decent grip and flex on a light rig, they have to be next to no psi and down that low they would often flex sidewall down to the rim and roll over. Almost too flexible.. These tires would impress the hell out of me sometimes and dissapoint me at others. They are horrible when wet.. An 8in rim would make them work much better, but red crawlers are what I want so these tires will never measure up... On the plus side, iroks are super tough, good on snow, and will impress the hell out of you from time to time. BUT In dry rocks and driving to and from the trails, 37in KM2's last longer and stick better... :twocents:
« Last Edit: Dec 14, 2009, 04:51:51 AM by peacesells63 »
this my man lysol, fresh out the joint
Steve_925
  • Male Posts: 1,876
« Reply #6 on: Dec 14, 2009, 01:20:56 AM »
i do know that the radials look way better. like peace said the bias look like baloons
UA 342
STEAMFITTERS
8485runner
  • Male Posts: 107
  • Member since Jun '09
« Reply #7 on: Dec 14, 2009, 06:25:33 AM »
It really depends on what your main use will be!  For just trails, go with the bias 36" Iroks. If you are gonna be driving on pavement alot, you would probably be better off with the radial!  I have 36" bias Iroks on 8" rims on my 4runnner and I love them!   They have impressed me many times!  On rocks, in the mud, they do great in many different types of situations!!
85 4runner, 36" Iroks, locked 5.29's, 30 spline Longs, MC 4.7:1 single case, bobbed 12"
96 4runner 2 1/2" daystar, 285/70/17 Pro Comp Xtreme Allterrains on black 17" FJ wheels
88 ext cab pickup bone stock, 1st gen tacoma wheels wrapped in 30x9.50x15 BFG Allterrains
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #8 on: Dec 14, 2009, 08:39:28 AM »
CORRECT! and a little cheaper :beerchug:
85_4RNR
  • Turtle Points: -23
  • Male Posts: 265
  • Member since Nov '09
« Reply #9 on: Dec 14, 2009, 10:30:41 AM »
The 36x13.50-15LT Iroks are taller, wider, and lighter than the 37x14.00-15LT Iroks. Makes me want a pair because 66 pounds is really light for a 37 i believe.   :best:
I work a 2000 BMW 540i 6 speed
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #10 on: Dec 14, 2009, 10:47:18 AM »
i have noticed that bias has a roundness to them, and the radial iroks are more flat on top. really dont look like balloons.
madhunt
  • Turtle Points: 52
  • Male Posts: 490
  • Member since Apr '06
« Reply #11 on: Dec 14, 2009, 11:07:37 AM »
i run the 37x12.50x15 radial iroks lovem, i dont like the bais they like said before ballon out to much. i have run 36x13.5x15 rads before, but i like my 12.50's better. me and Big B ( he runs 36x13.50x15 radials iroks) ran in the snow yesturday, up sky ranch and did not air down went past all snowmobile tracks and was making our own tracks and never got stuck nor did we have to air down, one of the best times up in the snow, if you any amount of driving  on pavement go with radials. if its a trailer queen then go bais. big thing to remember is you dont have to put alot of air in them for the street. i normally run somewhere between 20-25 psi for the street. thats where we were at yestuday in the snow. knee deep white stuff.
HIGH AND TIGHT OFFROAD
peacesells
  • Male Posts: 791
  • motley lou
« Reply #12 on: Dec 14, 2009, 04:29:31 PM »
This video is a perfect example of how low I had to air them down to get traction. At 2 minutes in they pinch almost to the rim... I was pretty impressed that I didnt slide all the way in the groove what with the rain and all
http://www.youtube.com/watch?v=ON7HeLpC6P0
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #13 on: Dec 16, 2009, 02:49:32 PM »
Bias all the way.  They'll flat spot if left in the same spot for a couple of days but it's well worth the improvement of a bias ply tires in the rockers vs. a radial.  My bias ply Iroks act like a wrinkle wall drag tire when aired down  :D
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Steve_925
  • Male Posts: 1,876
« Reply #14 on: Dec 16, 2009, 11:06:25 PM »
so what most people have said so far, if they have radials they love them and would always rund rads. the people with bias say the same thing about bias. unless im mistaken none of you have said that you've ran both bias and radial and like one over the other. i think piece did tho
UA 342
STEAMFITTERS
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #15 on: Dec 16, 2009, 11:25:45 PM »
i think it comes down to, whether you DD them or not.
sweetmeat
  • Turtle Points: -13
  • Member since Dec '08
  • Friends don't let friends join the sierra club
    • Wrecked4x4
« Reply #16 on: Dec 17, 2009, 09:13:50 PM »
I am currently runin 37 12.50 15 irok radials and am not happy with them. Sidewalls are way to weak. Next set i get will definately be bias. My radials are only 2 months old only beem out 3 times and 3 of the 4 tires are full of plugs on the sidewall. Maybe where most people go wheelin their fine but in so cal we wheel the hammers alot and bias is the only way to go. I learned my lesson the hard way :twocents:
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #17 on: Dec 17, 2009, 10:11:25 PM »
Sick video!  That kind of wheeling is why I love the Iroks!  They look like they were hooking up good.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« Reply #18 on: Dec 17, 2009, 10:18:19 PM »
Bias all the way for wheelin. But 6 months of daily driving 3 miles a day and 3 wheelin trips have mine down to 80% which sucks. I'll be looking for a set of 33 a/ts soon to run for daily driving. Off road they do great aired down to about 5psi and no bead locks and I've never ran off a bead.
86 mini truck 18" rays
09 highlander
70 suburban
tom415
  • Male Posts: 54
« Reply #19 on: Jan 04, 2010, 07:22:26 PM »
))--SLIVER-->
hey does any one have a pic of marlins rig with irocs....i wanna see?
84 xtra cab 37in mtr allied beadlocks 5.29s marlin front bumper longfields aussie lockers front/rear bed bobbed 16in hydraulic assist ifs brakes interior cage
83 toy 37in pitbulls on beadlocks 4.56s built toy axles flatbellied dual cases built 22re cam interior/partial exo
mattlosch
  • Turtle Points: 67
  • Male Posts: 703
  • Member since Sep '09
  • IBEW Local 48
« Reply #20 on: Jan 06, 2010, 06:13:59 PM »
so bias if not dd and radial if dd?? im trying to decide on tires and just cant decide.. do the bias really wear that fast?
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
Steve_925
  • Male Posts: 1,876
« Reply #21 on: Jan 06, 2010, 08:29:18 PM »
that is a definate yes. radial is made for the street
UA 342
STEAMFITTERS
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #22 on: Jan 07, 2010, 02:04:41 AM »
lets say this 6 months of dd maybe 3 miles a day 40 miles a week tore up my bias iroks to 80%.
09 highlander
70 suburban
Last post Mar 26, 2005, 04:14:11 PM
by mr4x42u
Last post Sep 27, 2006, 08:43:39 AM
by toyman1994
Last post Aug 27, 2010, 03:25:07 PM
by cdgvw1
Last post Oct 12, 2010, 12:02:42 PM
by Rallequip
Last post May 21, 2011, 09:40:44 PM
by yotatough
