I have a 1995 3vze 4runner with 202xxx miles on it and anyways im wondering what should the rpm be???....when i first got it the rpm would be at around 1500 (cold start) little more and some times alittle less and warmed up idle would be below 1000, from what i remember around 800...not sure if the rpms where rite so i adjusted my idle and know idles at the same at cold start and warmed up rite at 1000rpm...sometimes alittle more...does that sound rite???
and then my gas pedal...when i first got it it was soooo STIFF feeling, so i did the ISR mod helped alot, alittle bit of wd40 on the the throttle return spring, that helped, cleaned the the throttle while it was still attached so i didn't get it completely cleaned...thought i fixed it...no stiffness what in parked at ALL, just when im driving it at press it around 1\4 probably a little less than that and the stiffness is there...and then after the stiffness is gone, its just around that area....REALLY hard to explain my problem
Thanks if you read this
