Author Topic: Jake's 81 build, 40" Iroks coming soon  (Read 53333 times)
NCK4L
  • Turtle Points: -2
  • Male Posts: 522
  • Member since Oct '08
Re: Jake's 81 build, 40" Iroks coming soon
« Reply #150 on: Oct 17, 2010, 08:48:27 PM »
dang. i have an  e locker axle out of an o4 taco ill be puttin in my runner soon, it sounds like you would definitley recommend doing what you did to your taco axle?  i plan on wheelin my truck pretty hard and dont want to have issues with the axle housing.
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
  • Member since Oct '09
« Reply #151 on: Oct 17, 2010, 08:57:20 PM »
Yeah its a common failure.  Mine was cracked BAD around both perches.  I was using the stock 81 u-bolts and bottom plate.  The bottom plate was for a 2.5" axle tube not a 3".  I think those pressure points probably contributed to the failure.  I broke the housing on 37s running some pretty tough trails.  I definitely recommend it.
CSR73
  • Turtle Points: 7
  • Male Posts: 176
  • Member since Aug '10
« Reply #152 on: Oct 19, 2010, 06:23:33 AM »
This is probably my favorite 1st Gen build thread.  Low budget... but done right!
Your front shackle angle looks great for RUF with the stock front hangers.  Does your hybrid pack use the '81 main leaf?
'85 4runner in the works
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #153 on: Oct 19, 2010, 07:23:47 AM »
thanks!  yeah I am using the 81 main leaf
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #154 on: Oct 19, 2010, 02:23:42 PM »
Starting to accumulate more parts.  Twin stick, ARP knuckle studs, TG trunnion bearing eliminator, magnetic drain plugs, and some spacers.
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #155 on: Oct 19, 2010, 03:34:19 PM »
Its like christmas in your kitchen! lol
awhotrods
  • Turtle Points: 154
  • Male Posts: 1,203
« Reply #156 on: Oct 21, 2010, 10:24:26 PM »
I like this build, keep up the good work.
Mavericks
  • Turtle Points: 2535
  • Male Posts: 256
  • Member since Apr '08
« Reply #157 on: Oct 22, 2010, 09:46:19 AM »
I know your using ruf's did you end up also using the hole you drilled in the spring perch? good job fitting 40's, oh and more pics!
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #158 on: Oct 22, 2010, 10:09:07 AM »
no I didn't even try though.  I thought it'd contribute to spring wrap.  The front axle is far enough forward so I just left it in the stock holes.  I drilled them out of boredom :)
Mavericks
  • Male Posts: 256
« Reply #159 on: Oct 22, 2010, 01:21:27 PM »
good to know, I agree on the spring wrap. Keep up the good work.
81yotalove
  • Male Posts: 310
  • Member since Nov '09
« Reply #160 on: Oct 24, 2010, 02:27:33 PM »
i see you want to get some 4.7's to add to your duals now. stock cases not low enough now? im thinking of going duals instead of just 4.7 and contemplating selling my 4.7 kit for the money to buy the adapter and run stock in both. or would you say the dual ultimate setup is the way to go.
i love the new iroks by the way. i want to get some in a 37 flavor.
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #161 on: Oct 24, 2010, 04:03:37 PM »
When I had 37s the stock duals were plenty low enough.  I'm thinking with the 40s that 4.7s in the rear would be sweet.  I'm ready to quit working on it and go wheeling tho!  How much you want for the 4.7s??  :)
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #162 on: Oct 24, 2010, 04:06:36 PM »
Got my passenger side blinged this weekend.  I installed ARP knuckle studs, TG's trunnion eliminator (it took me about an hour to get the shims right) and did a 5th stud.
81yotalove
  • Male Posts: 310
« Reply #163 on: Oct 25, 2010, 12:17:08 PM »
im just going to wait till ti sell a few things to buy my adapter and keep the 4.7's it would be a waste of money to sell them plus i'll probably want them later anyways. do you have any pictures of your crossmember mount? if i remember you have a w56 so dual case crossmembers dont bolt up. i have seacrhed on here and pirate have ideas just curious to see what you did. thanks.
nice 5th stud. something i'll be doing later for sure.
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #164 on: Oct 25, 2010, 12:28:28 PM »
I ordered a skid for an 84-95 pickup.  I was able to use the factory rear mounts for the front holes of the skid.  I then welded some angle iron onto the inside of the frame and drilled holes.  I was only able to get 2 bolts in per side.  1 in the front 1 in the rear on each side.  It also had to be pushed to the passenger side about 3/4" of an inch.  Needless to say I'm not 100% satisfied with it but I've flogged on it without issue.  I'd like to get it centered and all 4 bolts in it, deer season is here though so I'll be hunting a lot more than working on my truck...
81yotalove
  • Male Posts: 310
« Reply #165 on: Oct 28, 2010, 03:25:48 PM »
that was basically my plan with the angle iron. but why does it have to be pushed to the passenger side? and have you seen sky-manufacturing's skid? im thinking of going with their's because you weld the side plates under the frame then use 3 bolts per side to install or remove the cases.
also i bolted on my 35's and flexed it. im axle is still in the sstock spot. with the wheels straight its fine. when they are turned they seem to touch a little but my springs are flat so now i see how you fit your 37's wit ruf and the stock hangers without a tub on the firewall.
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
Re: Jake's 81 build, 40" Iroks and all Toyota
« Reply #166 on: Dec 28, 2010, 09:53:03 PM »
Little bit of an update.  I got the driver's side done up to match the passenger side.  ARP studs, TG's trunnion eliminator etc.  Took it wheeling with no breakage  :greengrin:.  Still haven't got my twin stick installed.  I'm dreading pulling out the inter-locking pin without dropping the rear case (is it even possible).  I think with the new tires that it'll be a trail rig only now.  Which sucks I really enjoyed driving it on the road.  It is still streetable I just hate to ruin the Iroks on the street  :shake:  I'm wishing I didn't sell my 37s now, I should have kept them for street driving.  I should get out wheeling sometime before winter is over.  Here is the only video I got last time out.  I didn't air down
http://www.youtube.com/watch?v=xbMblPpu61c
I'd embed it if I knew how
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #167 on: Dec 29, 2010, 06:43:38 AM »
Wow that obstacle has really changed.
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #168 on: Dec 29, 2010, 06:57:17 AM »
Yeah they need to update some of their trail rankings.  That is supposed to be an easier trail.  I know it looks easy on the video but as always videos never do justice.  That is a big ledge.
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
« Reply #169 on: Dec 29, 2010, 07:10:48 AM »
The grade never looks as steep on video.  I've watched some video of my friends trucks spinning all fours on a hill that practically looks like level ground but in reality it was hard to even walk up.
81yotalove
  • Male Posts: 310
« Reply #170 on: Dec 29, 2010, 09:41:48 AM »
truck is looking sweet man. keep up the work. i just got my f 150's in lastnight. hoping to start on the ruf and hysteer sunday.
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #171 on: Feb 13, 2011, 11:02:28 PM »
Hopefully I'll get it back out this weekend.  I'll have my wife record some video too.
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #172 on: Feb 19, 2011, 11:17:41 PM »
had a good weekend no breakage!  very little body damage.  Believe it or not I didn't have ANY body damage from the flop.
It is weird looking out your mirror and seeing a heep oriented like this
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #173 on: Feb 20, 2011, 07:05:54 PM »
looks like your crawling on the Jeep LOL!
81yotalove
  • Male Posts: 310
« Reply #174 on: May 18, 2011, 05:29:42 PM »
whatever happened to this thing. i saw a for sale thread somewhere. do you still have it? still wheeling without issues?
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #175 on: May 18, 2011, 05:41:04 PM »
Yeah I still have it, still haven't broke anything.  It is for sale but I ain't in a big hurry to sell it either :)
81yotalove
  • Male Posts: 310
« Reply #176 on: May 18, 2011, 06:27:04 PM »
if you dont mind me asking, why are you selling it? you plan on building another rig once you sell this?
never really paid attention to winches till lately. i have been reading up on them. hows the 8274?
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #177 on: May 18, 2011, 07:07:50 PM »
I just don't get to go 4 wheeling much and would just pay off my Tacoma with the money.  I LOVE LOVE LOVE the 8274.
81yotalove
  • Male Posts: 310
« Reply #178 on: May 18, 2011, 07:47:05 PM »
you have a taco too nice. i wanted a taco so i could long travel it but then decided i wanted a solid axle.
i just scored an taco rear with e locker i might just retrofit my ifs housing so i dont have to deal with the weaker taco housing.
so the 8274 is that nice huh. with how big it is have you had problems with your approach angle with it always being up front?
81 swb 22re 35's
-Jake- [OP]
  • Turtle Points: 9
  • Male Posts: 538
« Reply #179 on: May 18, 2011, 08:05:53 PM »
yeah i whack it on rock ledges sometimes, but I could of moved it back a lot further than I have it.
Last post Jun 25, 2010, 08:01:27 PM
by Shamb
Last post Oct 29, 2009, 06:09:36 PM
by swapped89
Last post Nov 10, 2011, 05:06:58 PM
by 80firstgem
Last post Jan 14, 2022, 10:44:13 AM
by 252chad
Last post Nov 10, 2020, 10:49:45 PM
by Duffil
