Author Topic: SR5 Gauge Swap  (Read 1610 times)
rustyboltz
  • Turtle Points: -2
  • Member since Nov '09
SR5 Gauge Swap
« on: Nov 21, 2009, 06:04:54 PM »
I am fairly new to toyotas and still learning but I read in a topic that an SR5 gauge cluster will work in a 88 base 4 cyl 4 speed 2wd pickup.  Has anybody else tried it in this pickup?  What year or vehicle should I get the gauge cluster out of?  Would I have to change the fuel float or change the speed gear in the tranny to make the speed correct?
nor-cal yota
  • Male Posts: 216
  • Member since May '09
Re: SR5 Gauge Swap
« Reply #1 on: Nov 21, 2009, 07:09:10 PM »
Any 84-88 should be fine. You should change out the oil sending unit. It is pretty stright forward and easy.
I found this info about this swap.
Here is a link for that:
http://www.humboldt.edu/~pke1/Truck/
rustyboltz [OP]
  • Turtle Points: -2
Re: SR5 Gauge Swap
« Reply #2 on: Nov 22, 2009, 03:45:09 AM »
Thanks alot for the info.  It looks too easy on paper and I was just curious about it.  I want to have the gauges instead of the idiot lights and the tach.
SQUIRREL MONSTER
  • Turtle Points: 151
  • Male Posts: 657
  • Member since Jul '05
  • squirrel powered by hampsterous oxide!
Re: SR5 Gauge Swap
« Reply #3 on: Nov 23, 2009, 06:04:14 PM »
real easy swap. i used one from a 87 4x4 on my 86 2wd. just gotta run the tach wire direct from the negative side of the coil to the back side of the plug that goes into the tach side of the cluster...... here's the how-to
http://www.toyotaminis.com/forum/showthread.php?t=1685
rustyboltz [OP]
  • Turtle Points: -2
Re: SR5 Gauge Swap
« Reply #4 on: Nov 24, 2009, 04:58:33 PM »
I appreciate the reference to how to install the cluster.  I am going to a local u pull it and get a SR5 cluster and install it in the pickup.  Thanks.
Tool Pants
  • Member since Feb '07
Re: SR5 Gauge Swap
« Reply #5 on: Nov 26, 2009, 03:31:14 AM »
I have a 1988 22R 5 speed 2wd.  I put an SR5 cluster in almost 2 years ago.  It came from a 1987 4Runner.  There are several articles on how to do this.  You don't want an automatic, turbo, or 6 cylinder.  There are also 85 and 110mph clusters.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Last post Jun 17, 2011, 11:18:50 PM
by Fiercefirstgen559
Last post Apr 02, 2006, 07:23:24 PM
by 11 Bravo
Last post May 31, 2008, 09:39:08 PM
by T Pennington
Last post Jul 08, 2008, 01:31:10 PM
by jimbo74
Last post Dec 18, 2013, 09:54:38 PM
by CruelCrawler83
