Author Topic: marlin springs?  (Read 2508 times)
JOE 88
  • Member since Jan '09
marlin springs?
« on: Nov 20, 2009, 08:24:09 PM »
i just finished a SAS on my 88 toyota i went marlin everything  with 5in springs. now that it is done my front end seems to be an inch or two higher than the rear. is this normal ? and will my front settle throught time?
88 pickup marlin SAS 5in spring ARB's F/R  Dual cases 35' BFG KM2 5.29
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
Re: marlin springs?
« Reply #1 on: Nov 20, 2009, 08:38:18 PM »
probaly a bit  from motor weight and flexing it. :beer:  usauly it's the rear i think.  for the cargo weight that is going to be added.   my rear 6 inch was taller in the rear.
i love oregon wheelin.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
Re: marlin springs?
« Reply #2 on: Nov 20, 2009, 08:39:58 PM »
is it a runner?
JOE 88 [OP]
Re: marlin springs?
« Reply #3 on: Nov 20, 2009, 08:40:36 PM »
but is it normal for the front to be setting so much higher that the rear? with 5in marlin springs
JOE 88 [OP]
Re: marlin springs?
« Reply #4 on: Nov 20, 2009, 08:41:35 PM »
no it's not a runner it s a pickup
axled89
  • Male Posts: 2,526
Re: marlin springs?
« Reply #5 on: Nov 20, 2009, 08:42:07 PM »
i'm not sure cause the runners always sit low in the rear.  if you are that woried about it give them a call.
axled89
  • Male Posts: 2,526
Re: marlin springs?
« Reply #6 on: Nov 20, 2009, 08:44:46 PM »
are you sure you put the right spring packs in the correct spots rear in the rear and not the fronts in the rear??? :think:
JOE 88 [OP]
Re: marlin springs?
« Reply #7 on: Nov 20, 2009, 08:45:23 PM »
ya i might. i mean everything looks great . the rear is just a little lower. i think that it is more of a picky visual thing . i don't think its going to affect any performance.
axled89
  • Male Posts: 2,526
Re: marlin springs?
« Reply #8 on: Nov 20, 2009, 08:47:44 PM »
well cause the rear packs are thicker than the fronts. witch means the ride hieght is going to be different.
just make sure they are in the right spots. :biggthumpup:
JOE 88 [OP]
Re: marlin springs?
« Reply #9 on: Nov 20, 2009, 08:48:24 PM »
y am sure i put them on right . they are marked front and rear.
axled89
  • Male Posts: 2,526
Re: marlin springs?
« Reply #10 on: Nov 20, 2009, 08:50:03 PM »
ok. then did you relocate the shackle perches?? or change any mounting places??
JOE 88 [OP]
Re: marlin springs?
« Reply #11 on: Nov 20, 2009, 08:56:33 PM »
yes i did. what i did is buy the comlete marlin sas kit and the full matching rear kit as well. and im sure that all the perches and shackle placemnts are in the correct spot. but i had a hard time getting the parts from marlin. so im wondering if they sent me 4in springs for the back and 5in springs for the front.
axled89
  • Male Posts: 2,526
Re: marlin springs?
« Reply #12 on: Nov 20, 2009, 09:20:39 PM »
hey joe what year truck is this your working on?????????????????? :beer:  that may of happened you never know.
call services on monday i guess.
JOE 88 [OP]
Re: marlin springs?
« Reply #13 on: Nov 21, 2009, 11:34:02 AM »
hey thanks for all the input. Im going to call on monday and see what they say.  thank you
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: marlin springs?
« Reply #14 on: Nov 21, 2009, 11:59:40 AM »
Pics would be helpful
jeff94runner
  • Male Posts: 138
  • Member since Jun '08
Re: marlin springs?
« Reply #15 on: Nov 21, 2009, 02:54:37 PM »
x 2 on the pic's  :thumbs:
"Keeping the heavy light the heavy can be handled"
fatlife
  • Member since Mar '09
Re: marlin springs?
« Reply #16 on: Nov 22, 2009, 02:06:28 AM »
Are your shackles the same length?  Hows your shackle angle?
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
Re: marlin springs?
« Reply #17 on: Nov 22, 2009, 10:51:54 AM »
 :phone:
85_4RNR
  • Turtle Points: -23
  • Male Posts: 265
  • Member since Nov '09
Re: marlin springs?
« Reply #18 on: Nov 22, 2009, 04:04:58 PM »
The little bit of sag is sexy in my opinion. :D
I work a 2000 BMW 540i 6 speed
gray
  • Male Posts: 23
  • Member since Nov '05
    • photobucket
Re: marlin springs?
« Reply #19 on: Dec 15, 2009, 05:35:37 PM »
Well said at the bottom of your post,from another hard core toyota guy!!! :thumbs:
86 pick up 39's ,propane ,5:29's longs ,Detroit 's duel cases w/4:70 in rear case,twin stick,ceramic clutch ,rear disk brake convertion,cut and rotated front axle, inboard rear springs,exo cage,flat bed
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
Re: marlin springs?
« Reply #20 on: Dec 15, 2009, 06:21:58 PM »
Any pics or updates?
85_4RNR
  • Male Posts: 265
Re: marlin springs?
« Reply #21 on: Dec 15, 2009, 06:32:07 PM »
:headscratch: ???
gray
  • Male Posts: 23
    • photobucket
Re: marlin springs?
« Reply #22 on: Dec 15, 2009, 06:42:23 PM »
The part about you know you drive a toyota  when!!!
85_4RNR
  • Male Posts: 265
Re: marlin springs?
« Reply #23 on: Dec 15, 2009, 07:00:08 PM »
Thats what I thought you were refering too. yup how bout being in 3rd gear by the end of the intersection? :rofl2:
Last post Nov 11, 2004, 03:25:00 PM
by kneedownnate
Last post Jan 08, 2005, 06:18:02 AM
by rocktoy74
Last post Mar 24, 2006, 07:40:51 AM
by RustyToy
Last post May 03, 2006, 10:04:20 PM
by 84_yota_4wd
Last post Mar 16, 2009, 10:23:43 AM
by twistedtoy92
