That would work, though I typed in the wrong motor I think. I was following this old thread and the one I was looking at was the 5VZ.(hard to tell as the spacing is messed up a bit in that thread.http://board.marlincrawler.com/index.php?topic=48380.30Spending $3-4K on a fully modded 22RE motor or similar seems silly when you can just stuff a V6 in it and be done. If you wanted something more sane and a direct bolt-up, just get a 2TR-FE. The VVTi is a massive improvement and they're becoming somewhat affordable used. I'd rather have this engine than a 3RZ, having looked over all of the data over the last 48 hours or so.
Those are some huge welds!
back to the original post, do the fuel vent tube mod, flip the weber 180, remove the high speed circuit in the carb.... under 10 bucks and you can idle on your back looking up all day... and yes a fuel pressure regulator (lil more expensive but it DOES help)
I did the Weber Carb mod just recently (How to make a weber climb a hill). What are you talking about turning the carb 180?! High speed circuit?
I got sum low end came from LC and my 83 now smokes my buddys 91
22re throttle pedal, cable quadrant off early carb, lil bit of custom brackets.....gota mix of new and old pics click em to make em bigger
I was wondering if there is any advantage putting a 20r head on a 22r motor. I need to find a way to get a little more low end torque. My old truck was had a 20r in it and my new one has a 22r in it and they are pretty much the same truck besides the motor. The new one just feels gutless compared to the old one. I have the same size tires but the gears in the 20r were 5.33 and the gears in the 22r are 4.88s. My old truck had so much more power in the low end that at 1500rpm's it would still keep pulling. Now with the 22r if im not over 3000rpm's the motor is bogging. I had dual transfer cases in both trucks and i have simular problems when im on the streets or off. I have to reem the piss out of the 22r to get up the same hills that I putted up in the 20r. I have a header im about to put on the 22r. Any other ideas?
Started by 79rockcrawler Engine
Started by BIGBIRD « 1 2 3 4 5 » MCR11 (Sept 14-16, 2012)
Started by Sparkplug Rigs For Sale
Started by lexustech16 Engine
Started by ianf5 Newbie Questions
