hey guys, i just got done modding the early minitruck rear axle to accept the 97 e-locker i got out of the junk yard.
i noticed that i did not need to weld (although i did) there was enough meat on the flange to drill properly and should have sealed fine but i just did it anyways to be sure.
anyways, i was thinking of how to drill the holes without a drill press and have them come out perfect every time.
out of all the how to's out there it seems as everyone says not to install the 3'rd and then use a drill to make your holes using the 3'rd as the drill guide. mostly because you need to use a smaller drill bit then what the hole is and most likely it will not be centred.
i went to marshals (industrial hardware store) and bought 3 x 6 inch drill bits two to make pilot holes and one the correct size for the m8 1.25 tap, i ended up getting a 17/64Th's bit for the final pass.
i also picked up four nylon bushings the correct size for the corresponding pilot drill bits in order to keep the holes centered while using the 3'rd member as the drill guide.
the outer diammeter was the same thickness as the long studs needed for the e-locker, i believe it was a standard diammeter but the metric size is 8mm , i forget.
the inner diammiter must match your pilot drill bits, make sure they are a good fit!
i stacked 3 into the long holes by the actuator and it centred the hole perfectly, i then stepped up in size before i went full bore.
this was so easy and you do not need any fancy tools to do it.
there are tons of 4-runners in the junk yard thanks to cash 4 clunkers so- get to it !!
i also scored the 4wd locker computer and harness while i was at the yard. this makes the install so easy and clean!
if you get the complete harness , you only need to reconnect 7 wires from the e- locker to the computer, ground 2 run one lead to 12v and the other to 12v switched power
![Thumbs Up :thumbs:](https://board.marlincrawler.com/Smileys/marlin/thumbs.gif)
![](http://img.photobucket.com/albums/v399/drayday/IMG00046-20091030-2058.jpg)
![](http://img.photobucket.com/albums/v399/drayday/IMG00045-20091030-2058.jpg)
![](http://img.photobucket.com/albums/v399/drayday/IMG00043-20091030-2056.jpg)
![](http://img.photobucket.com/albums/v399/drayday/IMG00041-20091030-2056.jpg)
![](http://img.photobucket.com/albums/v399/drayday/IMG00039-20091030-2030.jpg)
