Author Topic: 22RE Fast idle on a switch - Help  (Read 2508 times)
87Fontana
  • Turtle Points: 378
  • Male Posts: 66
  • Member since Sep '06
    • My 4Runner pics
« on: Oct 23, 2009, 09:52:00 PM »
I am installing a York 210 compressor like the one Marlin uses for an onboard air system.  My truck normally idles around 750 RPM and the York compressor is recommended to work best at 1000-1200 RPM's.  I know their is some kind of fast idle circuit that is used for the air conditioning.  Does anyone know how I can tie into it with a switch on my dash?
Thanks,
Mike
1995 Toyota 4Runner, SAS, 35" Tires, 22RE
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
Re: 22RE Fast idle on a switch - Help
« Reply #1 on: Oct 23, 2009, 10:24:27 PM »
idle up vacume switch.
86bobbedtoy
  • Male Posts: 3,938
« Reply #2 on: Oct 23, 2009, 10:25:46 PM »
why not use a pull choke set up? on the throttle
you could use it for wheeling also.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #3 on: Oct 24, 2009, 12:43:16 AM »
Just tap into the AC solenoid that increases the idle speed for the AC.
Should be easy with a wiring diagram
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Oct 24, 2009, 09:32:15 AM »
Hand throttle works better. The way my OBA is set up I use the A/C switch to turn it on and off, it idles up but not enough. I use the hand throttle to bring it up to about 1200 RPM's
Last post Nov 14, 2005, 08:19:24 PM
by b_ripper8
Last post Jan 14, 2007, 06:46:04 PM
by RustyToy
Last post Jan 15, 2007, 06:42:44 PM
by cruzila
Last post Mar 09, 2008, 09:15:20 PM
by i_luv_my_truck
Last post Mar 07, 2009, 12:26:39 PM
by RABIDYOTA
