Or when you re timed it could be 180 deg out
If that were the case and everything else was working, it'd likely act like it was trying to start but pop and backfire.
when you time it you have to make sure it's at TDC on the compression stroke and to be absolutely sure you have to take the valve cover off and see that the rockers for cyl 1 are loose and cyl 4 are tight. then re-time it.
