I was messing with the 4runner tonight and noticed the clutch release arm on the bell housing has a extended tip w/small hole, like it was meant for a spring that would run from the clutch arm to the extended bleeder valve on the clutch slave cyl?? Mine currently does not have a spring in this location and wanted to check and see if there is supposed to be one? I did not notice anything in the FSM. Thanks in advance!!
Oops, forgot to add this is for a 85 4runner
