Author Topic: 87 cv joint noob question  (Read 1931 times)
87cascadel
  • Turtle Points: -1
  • Member since Aug '09
« on: Aug 22, 2009, 09:42:16 AM »
This is going to be really kindegarden compared to what everyone else knows about trucks. I have a 87 Yota 22re efi. THe CV joint are completely torn open In 4x4 if I turn it makes a loud clicking and i can feel the vibration in the front wheels. I want to fix it . eventuly I want to do a solid axle conversion but Im not sure i have the money right now so I was just wondering what advice you guys could give me. I'm a total noob and would greatly appreciate any and all. Thanks in advance.
TacoCrawler
  • Male Posts: 44
  • Member since Jul '09
Re: 87 cv joint noob question
« Reply #1 on: Aug 22, 2009, 10:13:20 AM »
I don't know the answer but I am gonna follow cause my truck does similar things and I want to figure it out as well
SAS 2002 Tacoma 3.4L, Dual cases, Tons, Etc.
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
« Reply #2 on: Aug 22, 2009, 05:33:39 PM »
The cheap and dirty trick is as follows:
If the boot is in pieces, remove it.  Get a water pik and a diluted mixture of simple green and water(bout 50/50, hot water plus SG)  Clean the crud out of the thing and rotate it while doing this.  This isn't as good as taking it all apart, but you shoudl be able to get 95%+ of it cleaned out.  Wash it out with clean water and let it dry overnight/for the rest of the day if hot.
Now you have axles without grease and a boot.  Humm...
My cheap and dirty trick with my last CV joint vehicle was to buy two sets of CVs - one slightly larger than the other.  They should fit snugly inside each other.   Get a 6-8 large, wide as possible zip-ties or hose clamps..  You're going to carefully cut a slit in the CV, put it the grease in/etc, zip tie it shut around each indent, then grease and zip tie the second one on top of the first with the slit on the opposite side.   This isn't perfect, but it certainly works as well as the bolt-together CV boots.   It will leak and ooze - so be it.  It should last 3-6 months at a time and hopefully until you get the SAS done.  Considering the PITA that a full CV job is this will at least get you going for a few months at a time.
Last post Jun 17, 2004, 03:53:04 PM
by SWAMPER
Last post Oct 03, 2006, 05:48:22 PM
by 79coyotefrg
Last post Nov 02, 2006, 09:45:47 PM
by nosnorb_808
Last post Mar 23, 2008, 06:45:06 PM
by kneedownnate
Last post Aug 22, 2009, 09:14:40 AM
by 79coyotefrg
