Marlin Crawler HD Clutch and FlyWheel - 75
Which of those ECU's puts out more power? Shipping for an ECU to 80026?
dibs on the doug thorley header and the fuel rail parts and throttle body. how much shipped to 02842? you take paypal? you know if these will fit on my 85 4runner?
3rd in line for header. Is it a smog legal one?
Pics of both please? Is it a marlin flywheel too? I'd need to pay with paypal and have it shipped to a business address in 96003.
I'd like to see a side pic of the clutch disc to see thickness, and assuming it's nice and thick you have yourself a deal I wish that throttle body would work for the next generation efi! Was it done locally?
I could use the following if you have them. Hit me up with a price.-Driver side bell housing stiffener(bolts to side of block, and tranny)-A set of bell housing bolts-Vsv valve for a/s for 22re (little green and black valve on the valve cover)-driver side water tube that goes to the heater tube-The 2 hooks to remove the engine with-The clutch soft line, and mount from down by the starter(basically everything that connects from the hard line, and goes to the slave)-Throttle cable if it's still in good shapeI may also be interested in the whole intake setup so if I could get a price with that as well that would be great.
Is the head still available?
is the distributer and coil for an r or re? I am guessing by the fact that everything else is for an re those would be as well. Let me know and pics if posible
Started by booger1 General 4WD Discussion
Started by GoYoTaGo « 1 2 » Engine
Started by ShawnS Engine
Started by 94MtnYote Project Research and Build-Ups
Started by zebracrawler Engine
