Am trying to figure out which crossember/skidplate combo to get? Am getting an headace trying to figure out which one is best and why.
I read alot already and there is no definite answer everyone thinks most of them are too rigid and could cause problems. Which i dont see how if installed correctly.
Am looking at budbuilts, frontrange, and 4xinnovantions but maybe not cause its tube and doesnt look as strong as the others.
The main problem is am switching over to a manual soon and need a new one anyhow unless my crossmember works which I doubt and it hangs too low anyhow.
Most clearance I could get would be nice. Its a 85x-cab
also Do i just jack up the t-case and trans with a floor jack then cut the tunnel and weld new mounts on the frame to hold it all together to get a flat belly and nothing with the engine mounts
