Author Topic: diff question?????  (Read 2678 times)
ihanberg
  • Turtle Points: 2
  • Male Posts: 98
  • Member since Feb '04
diff question?????
« on: Oct 11, 2004, 05:36:58 PM »
allright here it is i have an 85 4-runner 22re w56 and 4.30 gears with 31.10;50's the diffs have 312,000 miles on them and still function beautifuly anyways i was rumaging through a junk yard and found a 1998 yota pickup it has 4.30 gears and a locker a wasnt to keen on the gear ratio but the locker caught my attention is the guy said he wanted 500 bucks for the complete setup would it be a good idea to go this route? is it a simple bolt up deal or is there fabrication involved. im also considering a lift. its a daily driver so i dont want to get to wild with it it needs to be road worthy. anyways any suggestions? or thoughts i wont to Know everyones thoughts. :driving:
Mike D
  • Turtle Points: 122
  • Male Posts: 1,902
  • Member since Jun '04
  • MMMMMMMMMM........
Re: diff question?????
« Reply #1 on: Oct 11, 2004, 05:48:54 PM »
that is the toy electric locker deffintially get it if it comes with the housing.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • AKA Baja Brad
« Reply #2 on: Oct 11, 2004, 05:56:36 PM »
I think the only thing that needs to be done is to change flanges?  I don't really know about how the locker works (wiring?)  Othere then that i believe the springs should fit and then just what about the shock mounts.  Might be able to use your stock u-bolts and spring plate.  then brake lines should fit i would think.
Mike D
  • Male Posts: 1,902
« Reply #3 on: Oct 11, 2004, 05:59:21 PM »
well don't forget that there woild be coils in the rear and you would need to cut off the coil spring base thing and then weld on a leaf spring pearch.
ihanberg [OP]
  • Turtle Points: 2
  • Male Posts: 98
« Reply #4 on: Oct 11, 2004, 08:10:08 PM »
so do you think its worth getting and putting 4.88's in it? how about my other Q's any thoughts
ihanberg [OP]
  • Turtle Points: 2
  • Male Posts: 98
« Reply #5 on: Oct 11, 2004, 08:23:23 PM »
in answer yes it is complete. it actually looks brand new! but of course that doesnt mean anything oh yea i said it had 4.30's but im not sure the yolk was painted blue and from what i have read that means it has 4.30 gears.
robinhood4x4
  • Turtle Points: -180
« Reply #6 on: Oct 11, 2004, 08:52:45 PM »
If you just pick up the 3rd member, it's a little more involved then just bolting it up.  There's a little welding and drilling that needs to be done to the housing to get the 3rd member to bolt up.
Here's a writeup: http://www.4x4wire.com/toyota/tech/electric_locker/
« Last Edit: Oct 11, 2004, 08:58:53 PM by robinhood4x4 »
Quote from: cruzila
Well, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
BLUCRUZ
  • Turtle Points: 241
  • Male Posts: 470
  • Member since Mar '04
  • CA4WD LIFE MEMBER
« Reply #7 on: Oct 11, 2004, 09:15:03 PM »
GET IT! $500 for the whole unit is a good deal, see if you can score the wiring harness too if the truck is being parted out.
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
Mike D
  • Male Posts: 1,902
« Reply #8 on: Oct 11, 2004, 09:20:11 PM »
What size of tires are you going to be running with the 4.88's
ihanberg [OP]
  • Turtle Points: 2
  • Male Posts: 98
« Reply #9 on: Oct 11, 2004, 10:47:34 PM »
i have brand new bf goodrich ta radials 31:10:50's Eventually I will run 33's I just want to keep it as a daily diriver that goes off road occasionally.
Mike D
  • Male Posts: 1,902
« Reply #10 on: Oct 12, 2004, 04:23:46 PM »
well in that case you don't really need 4.88's untill you get a larger tire
Last post May 15, 2005, 08:48:11 AM
by Makman
Last post Sep 12, 2005, 07:09:24 PM
by Shamb
Last post Feb 26, 2006, 03:12:04 PM
by rotarex
Last post Mar 09, 2006, 05:57:08 PM
by kneedownnate
Last post Apr 17, 2006, 05:04:31 AM
by dieselsmoke
