you can usealmost any top mounted alt off a car. make sure the internal regulator is the same or switch it out. use a short piece of flat metal with 2 holes drilled to lengthin the stock alt bracket so the original belt will tighten up. also swap the serpantine pully with your v pully. this way you can use any top mount car alt on your truck since truck alts are scarce
