I just finished the blinkermod the other night but I'm probably not going to get a tubebumper. Around here (Iceland) we don't need tubebumpers that badly, a little support and protection under the factory bumper is quite enough.
I was thinking about putting foglights in the bumper cutout for the blinkers. Its common knowledge that foglights should be mounted low on the vehicle, but all the time I see foglights mounted at the same height or higher than the headlights on grillguards or tubebumpers.
I found these after a short google search, 6.5"x4" and they come as a HID low beam and a halogen high beam.
I thought I might use the HID, put in a 3000K bulb and adjust them as fogs.
But then I thought of the possibility of the lights getting damaged. That got me thinking of sealed beams or replacement headlights, those are usually cheap and should work fine as fogs.
Do you know about any good yellow rectangular lights that might fit the blinker cutouts with a little trimming and fabbed mounts?
