Author Topic: reinforced half doors?  (Read 976 times)
jji
  • Male Posts: 15
  • Member since May '08
« on: Apr 13, 2009, 12:32:59 PM »
So I got some free doors for a 91 extra cab and I thought i would make some half doors. I've got the basic design and shape I want for them but I can't find out how I want to reinforce them. I don't know if I want my reinforcement metal to be outside of the halfdoor or just inside for protection.
Has anybody seen any cool half door threads that could help me out or any input on this?
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: reinforced half doors?
« Reply #1 on: Apr 13, 2009, 12:35:43 PM »
Foam filler spray, get it from The Home Depot, will make for a much stronger door without even lifting a finger. Well you do have to lift a finger to spray it in. :gap:
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #2 on: Apr 13, 2009, 01:04:13 PM »
check out my build thread in project and research.  after I cut my doors, we sheeted the inside and capped it with 18 guage .  Doors are far more solid than stock, I can stand on the flat part with no problem at all.  And anyone who's seen me can vouch, I'm no small guy  :gap:
I didn't want to fill the inside, as I installed some speakers in the doors, and down the road I plan on fabbing up a pocket of sorts, a map pocket recessed into the door essentially.  Also, one thing I don't like about the spray is it really takes away the ability to fix anything inside the door if it goes bad, depending on how you set up the door latches and stuff.
              -Ronald Reagan
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Apr 13, 2009, 01:09:51 PM »
Boxing around the levers and such keep the inner workings accessible. A friend of mine did it that way and he can still get to them from an access door on the inside. I would just take mine off, and go open on mine. (samurai's)
jji [OP]
  • Male Posts: 15
« Reply #4 on: Apr 13, 2009, 01:35:09 PM »
Yeah I Kind've like the 2x4 idea but I am looking for something that will do more than support my weight. I want something that will stand up to some carnage from the v notch this year. :yesnod:
If i could find a way to make them as strong as tube doors but still give them the original body look I would be stoked. I definately plan on capping the top with sheet metal but i don't know what should go inside.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #5 on: Apr 13, 2009, 01:50:59 PM »
If you don't care about the look of the outside, I've seen angle iron welded parallel to the ground on the door, with the corner pointed outward.  I think 4runnrrick did that, I don't remember though.  I guess you could do the same on the inside of the outter door panel, it would give it some additional rigidity for sure.
              -Ronald Reagan
Talon84x4
  • Turtle Points: 375
  • Male Posts: 919
  • Member since Mar '06
« Reply #6 on: Apr 13, 2009, 05:38:42 PM »
I just welded the cap to the top and left the inside and backside open to use for trail trash. I think they're stronger and can take a hit better than a stock door just like that.  :twocents:
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #7 on: Apr 13, 2009, 06:03:15 PM »
I think just welds some stuff in   make a cubby hole and cup holds
jji [OP]
  • Male Posts: 15
« Reply #8 on: Apr 13, 2009, 07:43:01 PM »
yeah I decided I am going to cap the top with sheet metal and put on some strong welds to give it some strength. I'm a little strapped on cash anyways so that looks like the best way to get some desent half doors. thanks for the input. I'll post up some pictures on my progress in a bit.
Last post Feb 16, 2013, 07:56:43 PM
by gmack192
Last post Mar 30, 2005, 08:29:33 PM
by wmflyfisher
Last post Jul 25, 2005, 07:10:45 AM
by chim
Last post Aug 20, 2006, 10:23:54 PM
by ladderrack guy
Last post Feb 21, 2008, 02:38:06 PM
by eric hohlfelder
