Author Topic: 80' cluster in a 88'?  (Read 783 times)
Moit88RNR
  • Turtle Points: 39
  • Male Posts: 360
  • Member since Jun '08
« on: Apr 07, 2009, 08:37:12 PM »
simply, Will it work?
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: 80' cluster in a 88'?
« Reply #1 on: Apr 07, 2009, 10:36:42 PM »
'79 to '81 Toyota clusters use 2 round plugs with round terminal ends.
'82 and newer use 3 or more flat plugs with flat pins.
Therefore major wire changeover required.
Oil sender idiot light---no problem
Gas tank sender---no problem but will drop quickly when empty
Water temp---no problem, will now read 1/4 gauge at 180 degree
Tach---no problem if 4cyl, way off and wrong if V6
Speedometer---no problem, will clip right on
All outher functions will work but you have a lot of custom wiring ahead of you.
This is not advised unless you are familiar with Toyota clusters.
Marlin
Moit88RNR [OP]
  • Turtle Points: 39
  • Male Posts: 360
« Reply #2 on: Apr 08, 2009, 03:23:12 PM »
Thanks Marlin. thats all i needed to now plus more. just thought it would be kinda cool to have 1st gen. cluster in an 88 and also i would gain the tach. the only down side would be keeping track of the milage. if i go through with it i will b sure to post pics.
Thanks, Mike
Last post Feb 19, 2007, 04:53:58 AM
by Plowking
Last post Nov 06, 2009, 04:46:33 PM
by trekkerpaul
Last post Jul 17, 2008, 06:45:12 AM
by beyondlogic
Last post Feb 17, 2010, 09:47:23 PM
by fade
Last post Nov 08, 2010, 07:08:58 AM
by 22hilux
