Author Topic: Oil pump  (Read 1419 times)
Grunt
  • Turtle Points: -1
  • Male Posts: 32
  • Member since Mar '09
  • Improvise,Adapt,Overcome
Oil pump
« on: Apr 01, 2009, 03:33:51 PM »
This might be a total noob question,but,(I am a noob) just did a timing chain on my 86 pickup. Now I have a leak at the bottom of the oil pump. I'm thinking I must have rolled the o ring out of the milled slot in the pump body. Leak is there when truck is running, pressure from pump is my best guess. Is there a trick to sealing this up? Thanks in advance for any help. Have a new o ring on the way.(me and the NAPA people are seeing alot of each other these last few days) Later Mac
With your shield or on it
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Oil pump
« Reply #1 on: Apr 01, 2009, 03:53:30 PM »
Are you sure it's not the oil seal?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
SolidAxle
  • Turtle Points: 6
  • Male Posts: 365
  • Member since Oct '05
  • My truck is 5 years older than me
Re: Oil pump
« Reply #2 on: Apr 01, 2009, 04:12:31 PM »
if that little o-ring slipped out at all and got pinched then thats the problem. I like to coat it in grese so that it sticks in its groove when i put it together. It may be the seal though  :imwithstupid:. If theres a groove in the crank pulley from where the seal was riding you can sand the seal down so that when you bottom it out in the pump it rides in a different spot on the crank...pulley.
Grunt [OP]
  • Turtle Points: -1
  • Male Posts: 32
Re: Oil pump
« Reply #3 on: Apr 01, 2009, 04:20:21 PM »
The back of the pulley is bone dry. The front seal seems to be good. No burrs or issues with install. I'll give grease a shot. This is turning into a PITA. Thanks for the help, first Toyota, cool little truck. Later Mac
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
Re: Oil pump
« Reply #4 on: Apr 01, 2009, 07:32:36 PM »
The oil pump bolts are supposed to have a sealant applied to the threads when the pump is installed. Did you do this? If not, that could be the source of the leak. I believe the top bolt is the one that usually seeps oil out.
SAVE TELLICO post 491
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Oil pump
« Reply #5 on: Apr 01, 2009, 11:49:44 PM »
probably that wierd shaped huge o ring.... i had that leak before, pinched it after my timing chain. spent the $10 on the oem and the leak was gone
Grunt [OP]
  • Turtle Points: -1
  • Male Posts: 32
Re: Oil pump
« Reply #6 on: Apr 02, 2009, 04:39:56 AM »
Tearing into to it this morning, hope to be driving it today. Again, thanks for the help. Later Mac
Grunt [OP]
  • Turtle Points: -1
  • Male Posts: 32
Re: Oil pump
« Reply #7 on: Apr 02, 2009, 02:53:01 PM »
Well it was the o-ring. Rolled out of groove when installed. Replaced, all is well. Thanks for the push in the right direction. Later Mac
SolidAxle
  • Turtle Points: 6
  • Male Posts: 365
Re: Oil pump
« Reply #8 on: Apr 02, 2009, 03:09:28 PM »
Good to hear you got it fixed up.
Oil Pump
Last post Jan 20, 2005, 10:45:42 PM
by FATB0Y
Last post Jun 12, 2005, 10:39:10 PM
by lilbuddy
Last post Feb 19, 2006, 05:10:21 PM
by toymech
Last post Jul 18, 2006, 06:05:34 PM
by boggerunner
Last post Jun 20, 2006, 09:32:30 AM
by Mike D
