Author Topic: Knuckle swap  (Read 1496 times)
Uncle Buck
  • Member since Apr '09
Knuckle swap
« on: Apr 01, 2009, 01:30:30 PM »
I'm doing a disc brake conversion on my '70 FJ40, using the knuckles from a FJ60.
If I keep all of the top and bottom shims in their original orientation, will I need to go through the whole process of centering the knuckle to the axle shaft?  I've read that you don't have to re-center everything when rebuilding an axle if the shims are kept in the original place, but I'm not sure if that applies in this case.  FWIW I'm going to use Marlin's HD seals.
Goose
  • Turtle Points: 52
  • Male Posts: 1,029
  • Member since Mar '07
  • >>Goose maN<<
Re: Knuckle swap
« Reply #1 on: Apr 01, 2009, 02:55:46 PM »
bump on this for a good tech question..
any fj guys care to throw in some insight?
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • 1St Gens Rule!
Re: Knuckle swap
« Reply #2 on: Apr 01, 2009, 03:26:52 PM »
I have done it like that in past and it worked fine.  :thumbs:  I would still recommend measuring the pre-load to be on the safe side  :turtle3:   No reason for DW
« Last Edit: Apr 01, 2009, 03:44:12 PM by Uncle Buck »
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
Uncle Buck [OP]
Re: Knuckle swap
« Reply #3 on: Apr 01, 2009, 03:45:34 PM »
I was definately planning to check the pre-load, which is pretty easy using a fishing scale.  But centering the knuckle to the axle requires a
"special" (translation: EXPENSIVE!) tool that I don't have and would rather not buy.
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • 1St Gens Rule!
Re: Knuckle swap
« Reply #4 on: Apr 01, 2009, 03:59:21 PM »
I have never centered one either. With the HD inner seals you will be fine
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Last post May 17, 2003, 06:44:51 AM
by Drip_Torch
Last post Dec 15, 2003, 01:34:13 PM
by ToyotaGuy
Last post Dec 09, 2006, 12:47:10 PM
by 42s on u
Last post Apr 13, 2008, 09:22:05 PM
by Steve_925
Last post Jan 22, 2011, 03:04:08 PM
by Dooner
