Author Topic: the never ending oil problem  (Read 1172 times)
red runner
  • Member since Jan '09
« on: Mar 24, 2009, 06:26:14 PM »
all u guys probly seen me post about this a lot but ....i had oil in my coolent the oil wasnt milky i pulled the head the gasket was in pretty good shape a burnt spot where the head was eating away ...got a weild on it and had the head checked out and shaved the head ...and the head was good .....i was thinking could the problem come from the timing chain cover my buddy said they can wear from time and cause that to happen its a 20r thanks guys
...P.S sorry about many posts about it but my question is about the timing cover =p :smack:
« Last Edit: Mar 24, 2009, 06:35:12 PM by red runner »
dniel
  • Male Posts: 194
  • Member since Feb '09
Re: the never ending oil problem
« Reply #1 on: Mar 24, 2009, 07:03:11 PM »
I have no experience with the 20r but I have seen many 22r were the timing chain has worn through the cover. This could be your problem. If you are careful you can take off and put on the timing cover without damaging the head gasket. If you had the head milled and did not shave the timing cover to match this might cause a problem.
1uz-fe, 1 tons, 44" tsl
MC387
  • Turtle Points: -4
  • Member since Dec '06
« Reply #2 on: Mar 25, 2009, 08:03:39 AM »
You dont have to mill the timing cover unless you deck the block.  Pull the valve cover and see if your timing chain is loose.  You can also look in with a flash light and see if the guide is broken.  If the guide is broken then there is a good chance that your cover is junk.  If the guide is intact, It is doubtful that you cover is damaged.  This would be the straight guide.  Dniel is correct though.  You should be able to remove the cover with the head still on.  Be sure to change all timing parts and the front seal if you go through the trouble.
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #3 on: Apr 01, 2009, 03:40:13 PM »
I'd like to add. Drain the coolant and DO NOT disturb the head. You'll be ok then. If you do see that the guide is broken. Replace them with metal guides not the stock plastic ones.
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #4 on: Apr 01, 2009, 03:44:17 PM »
just a fyI     befor i got my 84 celica   it was my moms then my sisters   the T-chain was never done   when i did a rebuild  all the wear pads where in the pan  and the double roller chain ate 90%+ threw the cover   had no choice at the time to reuse itday it cracked  lost ally my oil and $500  J-yard moter
Last post Nov 13, 2007, 10:11:19 PM
by cruzila
Last post Jun 01, 2004, 09:28:35 AM
by superstarai
Last post Jun 15, 2004, 10:29:21 AM
by superstarai
Last post Feb 29, 2008, 06:10:05 PM
by weirdtimes_7
Last post Jul 19, 2015, 07:21:03 PM
by kneedownnate
