Author Topic: Front diff swap.Pls Help!!  (Read 1176 times)
Siringo
  • Male Posts: 96
  • Member since Apr '06
  • I Really Have No Idea...
« on: Mar 21, 2009, 07:51:29 PM »
Hi,
I've never done any work on the front of my Hilux, so I'm venturing into unknown waters here and I'm looking for some help.
I've just replaced my diff front and rear diff centres (3rd's). The rear was a breeze, but the front is causing me some problems. I've got everything back together and it all looks OK. I put the truck up on 4 floor stands and put her into 4WD, put it in gear, and started the motor to make sure the front wheels were engaging.
One front is OK, the other just floats around, you can actually spin it backwards. I put everything back together by the book and torqued everything up to the correct specs and everything looks OK, it's just this front wheel. When I was putting the axle back in I could never spin the axle and see the diff rotate and vice versa, when I span the diff centre, I could never see that front axle rotate. It's like it hasn't plugged into the diff properly.
Is this normal or have I stuffed something up???? Everything looks like it's pushed in far enough, everything lines up fine.
Thanks for any help.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
Re: Front diff swap.Pls Help!!
« Reply #1 on: Mar 21, 2009, 08:10:36 PM »
If your front dif is stock and has an open differential than that is normal.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #2 on: Mar 21, 2009, 11:27:15 PM »
X2
Sounds normal
You'll never take me alive
Siringo [OP]
  • Male Posts: 96
« Reply #3 on: Mar 22, 2009, 12:00:45 AM »
Thanks for the replies guys I really appreciate it. After I posted I went back out and ripped off the free wheeling hub. I think I had put it back on in such a way that it wasn't engaging properly. I sat down and had a real good look at how it all works and now know, so I guess it wasn't wasted time.
After putting it all back together again, I was able to stop both front wheels (one at a time) and the other kept spinning. So I agree, it was all normal.
Many thanks again.
Last post Aug 13, 2004, 06:08:50 PM
by burl4x4
Last post Mar 28, 2006, 06:56:54 PM
by 89 toy
Last post Jul 13, 2006, 03:29:38 PM
by BLACKDOG
Last post Dec 16, 2015, 06:53:31 PM
by mdtrail-toy
Last post Sep 20, 2019, 04:44:50 AM
by gnob
