Author Topic: Can't remove rear brake drum....  (Read 4464 times)
sggirbyt
  • Male Posts: 27
  • Member since Sep '08
  • Beat you like you owe me money I will
« on: Mar 17, 2009, 10:33:29 AM »
on my 87 4 runner. I noticed i had brake fluid leaking from the PS rear drum and tried to remove it with no luck. I tried using bolts in the threaded holes on the drum itself, still nothing. What am I doing wrong? I have never had this much of a problem trying to remove a drum.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: Can't remove rear brake drum....
« Reply #1 on: Mar 17, 2009, 10:38:31 AM »
I've had a few that were difficult before.   I used a hammer and a pry bar on the back lip of the drum itself.   good luck.
I like to Drive!
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #2 on: Mar 17, 2009, 10:44:24 AM »
Dont use a hammer and pry bar! there is a little oval slot on the axle side of the drum. If you use 2 flathead screwdrivers push the smaller one in the hole and you will see a ratcheting wheel in there. Spin the wheel the opposite way it would ratchet that will release the pads. Look at the one you already have off and this will make more sense.
You'll never take me alive
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #3 on: Mar 17, 2009, 10:55:10 AM »
I was assuming he had already tried that.   When I had to do that I had already backed out the adjuster.
I like to Drive!
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #4 on: Mar 17, 2009, 10:58:21 AM »
I have deffinatly beat and broken my fairshare of drums. hahaha
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #5 on: Mar 17, 2009, 10:59:01 AM »
and make sure your Ebrake is off!!!
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #6 on: Mar 17, 2009, 10:59:43 AM »
:yesnod:
Just be mindfull of the backing plate.
I like to Drive!
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #7 on: Mar 17, 2009, 01:06:25 PM »
when you tried the bolts to press the drum off were you tapping on the face of the axle as you tightened the bolts?
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
« Reply #8 on: Mar 17, 2009, 01:22:21 PM »
you might end up ripping the lining off of the shoe....thats what happend to me when i did it :hammer:
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #9 on: Mar 17, 2009, 03:18:34 PM »
What is this *tapping* you are referring about?  If you mean grabbing the biggest dead blow you have and beating the living snot out of it.. Then I concur!
Get longer bolts!!  Tighten them up a bit, then start *tapping*.  Repeat until the drum falls off.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #10 on: Mar 17, 2009, 04:24:39 PM »
:imwithstupid:  i actual am guilty of NOT doing that a couple days ago on a friends truck, i was beating the crap out of it and then after a few :headscratch: :headscratch: :headscratch:
i asked him if he set the parking brake, he said "well duh, your supposed to when you jack it up"   :rofl:  i felt like such a idiot for NOT telling him first to leave it off :wall:
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #11 on: Mar 17, 2009, 04:44:48 PM »
When all else fails I , disconnect the e-brake cable, disconnect the brake line, take the four bolts that hold the axle on the housing. Pull the whole thing out, lay a piece of 2 x 8 on the ground and slam the axle, lug studs down on it. 1-2 slams and the drum pops off if I remember to back the adjuster off.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #12 on: Mar 17, 2009, 04:50:16 PM »
Is it rust welded in the center or are the shoes holding it on?
For the shoes, back them off........
If rusted welded, I've put a gear puller on the drum,
then start the engine up,
put in first gear, let clutch out, put clutch in
put in reverse, let clutch out, put clutch in
alternate between 1st and R to walk drum off the hub.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
sggirbyt [OP]
  • Male Posts: 27
« Reply #13 on: Mar 17, 2009, 08:46:25 PM »
The E-brake is off, I backed out the adjuster and "tapped" it with a 16oz ball peen hammer while trying the bolts, still no luck. I am next going to try OOPS suggestion. Thank you for all the replies fellas, I will let you know the outcome within the next couple days.
  • Turtle Points: 1088
  • Male Posts: 9,756
  • Member since Oct '04
« Reply #14 on: Mar 17, 2009, 11:30:05 PM »
I have one drum on my 4by that won't come off, probably worn down too far.  I just figured when I really felt like dealing with it I'd stick a cutting wheel on the die grinder and go to town!
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #15 on: Apr 02, 2009, 12:27:38 PM »
Well? I'm biting my nails. How'd it go?
95yotakid
  • Turtle Points: 27
  • Member since Jan '09
« Reply #16 on: Apr 02, 2009, 10:58:14 PM »
try shocking it hitting it in between the studs and the give it a pull
sggirbyt [OP]
  • Male Posts: 27
« Reply #17 on: Apr 27, 2009, 09:36:28 AM »
I have been SUPER busy at work, I am finaly going to get after it today. I will post results :P
Last post Dec 27, 2006, 01:01:06 PM
by Stinky
Last post Oct 09, 2008, 09:31:48 PM
by toyconvert
Last post Dec 09, 2013, 04:02:54 PM
by Rockdwg
Last post Nov 02, 2012, 05:59:17 PM
by desrodunes1
Last post May 18, 2019, 03:28:24 PM
by Toybrota
