If you are running 5.29's and 35's on a fresh rebuild, and having power problems, then something is wrong. I am running the same on a 250k mile engine (original rings, with replaced HG and rod bearings, no smoke, but uses 1 qt of oil per tank of gas), and can run 70 at half throttle. I would take another look at the engine - timing, plugs, sensors, carb... something is killing your power. The 22r should be making enough power to push you.
Started by cgbemis Engine
Started by burnyota Parts Wanted
Started by chevyLUVtoyota Parts Wanted
Started by RustyToy Project Research and Build-Ups
Started by 1982toy Engine
