Author Topic: 22R exhaust manifold studs  (Read 8387 times)
vincesyota
  • Member since Feb '09
« on: Mar 03, 2009, 04:36:25 PM »
What size are the exhaust manifold bolts, on 82 22r motor ? I need to helicoil a couple of them I called
Toyota in my area, and they did not know. I have a header leak.
I was going to make a brace from the motor or bellhousing to help support, the header from any flex in the
future.
Any ideas or suggestions while I'm doing the work?
82juguete
  • Member since Jan '07
Re: 22R exhaust manifold studs
« Reply #1 on: Mar 03, 2009, 04:47:22 PM »
not sure about the stud size, but if i remember correctly, there should be a stock support from the header to the bell housing...Maybe yours just needs replacing and not a custom fabbed one
94MtnYote
  • Turtle Points: 6
  • Member since Oct '07
  • - 94 std cab-
« Reply #2 on: Mar 03, 2009, 04:51:55 PM »
Give LC engineering a call, they have information on size and thread pitch.
 Marlin 1200LB clutch
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #3 on: Mar 03, 2009, 05:49:08 PM »
10x1.25
vincesyota [OP]
« Reply #4 on: Mar 03, 2009, 08:22:12 PM »
  Thanks Guys
83MT
  • Turtle Points: -23
  • Member since Jun '08
« Reply #5 on: Mar 04, 2009, 09:41:26 AM »
Napa Balkamp Helicoil Metric Thread Repair Kit
M10x1.25
Part #7703020
12 inserts
HEL-5543-10
This was posted somewhere. Apparently it may even be made specifically for Toyota exaust studs??...
Zach
I like Yotatech
KYOTA
  • Wreckin Ball '09
« Reply #6 on: Mar 04, 2009, 05:06:15 PM »
Vince if you're talking about a stock exhaust "header" or downpipe, I have the stock support bracket that bolts to the bellhousing off my 83, let me know if you want it
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #7 on: Mar 04, 2009, 06:15:38 PM »
I used threaded inserts for a 3/8" stud.
The stud is slightly smaller, but it shouldn't matter.
The advantage is that threaded inserts are stronger than helicoils when going into aluminum, and less likely to pull out.    The SAE sized threaded inserts are also lots cheaper than helicoils or even metric threaded inserts, and use common tap sizes.
I think the OD of the threaded insert I used was 1/2x13  ID 3/8x16.
The drill size for the 1/2x13 tap is just slightly larger than 10mm, so it's easy to drill out the hole, and tap it...........
Check for manifold warpage, and get it surfaced flat if it is warped.
BTW, I tried to cheap out and replace 1 broken stud, with a trial fitting after the 1 stud replacement another stud broke, so at that point I replaced them all.........
Last post Feb 03, 2004, 07:55:31 PM
by XYRS2LT
Last post Dec 28, 2004, 04:56:22 PM
by Uncle Jesse
Last post Feb 13, 2006, 06:53:42 PM
by kneedownnate
Last post May 19, 2012, 02:58:33 PM
by Slolyfe
Last post Feb 16, 2017, 07:18:10 AM
by Cheesemaker
