Author Topic: Wiring guru's  (Read 2011 times)
swamp_fox
  • Male Posts: 53
  • Member since Oct '06
Wiring guru's
« on: Feb 24, 2009, 07:49:49 PM »
I recently pulled the bed of my truck to get to the fuel pump and now that its off I really think I want to build myself a flat bed.  My question is, I want to run flush mount LED's like these http://www.ledtrailerlights.com/stt/stt_M85429R.htm .  How hard would it be to wire these up so everything would work including the reverse lights...Also want to keep the stock tag lights to put above my tag!  I read the post on Pirate about wiring these but it was like reading greek since I have 0 wiring experiance!
99 4Runner Limited 4x4
89 Reg Cab v6 4x4
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
Re: Wiring guru's
« Reply #1 on: Feb 25, 2009, 08:07:06 AM »
Link to the pirate post?
You can use something called a Trailer light converter kit.  Wiring instructions will be included in the kit.
You'll want to add anoter light(clear) as red reverse lights suck.
swamp_fox [OP]
  • Male Posts: 53
Re: Wiring guru's
« Reply #2 on: Feb 25, 2009, 10:53:22 AM »
well those lights in that link have an 18 white light reverse light around the brake/tail light.  Thats why I like that light.  here's the link to the pirate post. http://www.pirate4x4.com/forum/showthread.php?p=5329844#post5329844
89 Reg Cab v6 4x4
swamp_fox [OP]
  • Male Posts: 53
Re: Wiring guru's
« Reply #3 on: Feb 26, 2009, 10:28:22 AM »
no other input.  I'm planning on fabbing the bed up pretty soon and would like to do this.
89 Reg Cab v6 4x4
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Re: Wiring guru's
« Reply #4 on: Feb 26, 2009, 03:05:18 PM »
The wiring kit should come w/what you need.  You will have to splice the wires into the oem wiring, the lights will operate just like trailer lights, i.e., one light does everything brake/tail/blink.  You could also design the bed to reuse the original lights from the oem bed.  The over all look will depend on the design of the f-bed.
swamp_fox [OP]
  • Male Posts: 53
Re: Wiring guru's
« Reply #5 on: Feb 26, 2009, 07:47:47 PM »
Well I dont really want the OEM lights.  I was just gonna fab up a tube bed and put some sheet metal on the end and mount the tag in the middle with the led's on both sides.  And still use the OEM tag lights above it!  I'll just try it and see and see what happens.
89 Reg Cab v6 4x4
Hawk Thor
  • Turtle Points: 5
  • Male Posts: 112
  • Member since May '08
Re: Wiring guru's
« Reply #6 on: Feb 27, 2009, 03:03:19 PM »
What about using lights sold at big rig shops, the ones used on semis and towtrucks ? Those are usually durable, can be had as one big lighthousing or multiple lamps that you arrange the way you like. You can get those as incandescent or LED, flushmounted or fitted on the back of the bed, square, round, oval you name it. You could use most of your OEM wiring but you'll need to splice the lights and probably lengthen or shorten the wiring to best suit your mounting location and wire routing.
I would also mount some worklights/tractorlights on the back to act as back-up lamps and to light up camp at night. You could relay them via the reverse lights and to a switch, so you can either turn them on or they turn on automatically when you reverse.
Snowtoy
  • Male Posts: 2,583
Re: Wiring guru's
« Reply #7 on: Feb 27, 2009, 11:28:51 PM »
I installed these cheap plastic ones from Kragen's, nice and bright for only $20, plenty bright.
As mentioned run a relay w/its own 12volt power source and your back-up lights will be as bright as headlights.  I almost went w/100watt flood lights, but then figured it would be a bit overkill.
Last post Feb 12, 2006, 09:06:56 PM
by MidgetMike
Last post Sep 30, 2007, 12:33:42 PM
by Ruari
Last post Apr 29, 2009, 05:19:24 AM
by Bazzi
Last post Feb 21, 2013, 06:21:19 AM
by Rocksurfer
Last post Dec 14, 2014, 09:55:10 PM
by 1985CRAWLER
