Author Topic: head gasket?  (Read 2537 times)
yoda4x
  • Turtle Points: 84
  • Member since Jun '04
head gasket?
« on: Sep 23, 2004, 06:01:44 PM »
my truck starts and runs okay, but once it gets warm i lose compression in the first two cylinders.  i dont have any water in my oil.  i was told this is the head gasket, but i am not sure.  could it be the rings or valves?  kind of has me confused.  any help is appreciated.
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
  • Member since Oct '03
Re: head gasket?
« Reply #1 on: Sep 23, 2004, 06:36:44 PM »
Run a compression test on it.  If those two cylinders are low, could be most likely a head gasket.  Maybe pop the valve cover and see how the rocker arms are rocking.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: head gasket?
« Reply #2 on: Sep 24, 2004, 01:45:46 AM »
I have seen the head gasket blow between the 1th and 2ed cylinders. Remove both the 1th and 2ed spark plugs and run compression.
However, it sounds like you have tight valves :crossed:
             cold      hot
Intake    .006      .008
Exhaust  .010      .012
Retorque the head and adjust the valves
Cold  57 lbs.
Hot   63 lbs
Marlin
blyota91
  • Male Posts: 170
Re: head gasket?
« Reply #3 on: Sep 24, 2004, 04:06:05 AM »
Marlin, as to those valve tightening specs, I have a cam in my truck and the spec sheet for it says to adjust both to .010 when hot.  I've done this a couple times and the still make noise.  Should I try factory specs on theses adjustments?
Andrew
http://www.cardomain.com/member_pages/view_page.pl?page_id=397976
Retiring the 91
Rebuilding the 94
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: head gasket?
« Reply #4 on: Sep 24, 2004, 09:28:26 AM »
I would recommend running slightly tighter on the intake side since they do not get as hot and expand less. The reason the cam sheet probably tells you to run them slightly loose is maybe to decrease valve overlap on the exhaust/intake stroke to give you better performance at lower rpms. Makes since if its a pretty aggressive cam, but its really not going to make much difference if you ask me.
Tighten up your intakes to prevent them from hammering out the seats. You dont need to worry about burning an intake valve as you would an exhaust.
Last post Apr 05, 2005, 12:57:07 PM
by Rebeltilldeath3
Last post Nov 04, 2005, 07:02:27 AM
by 4runnerfromhell
Last post May 14, 2006, 12:54:29 PM
by unclejpl4x4
Last post Feb 01, 2013, 08:53:32 PM
by Cheesemaker
Last post Aug 04, 2017, 06:04:10 PM
by OVRAROK
