4runnerchevy and his Chevy powered 86
Started by 4RunnerChevy, February 14, 2009, 08:21:13 AM
4RunnerChevy
Quote from: fordh8r on September 26, 2011, 03:13:44 PM
Oh, got it! It's because the VSS you're using also incorporates the cable drive for your speedo! Wasn't thinkinh about that. Yeah, already familiar with every other aspect of the electronics. Been wrenching on this stuff since way back! :)
I know, that's why your build will be awesome. Yes the VSS is part of the cable drive.
fordh8r
Awesome! And thanks! :beerchug: I figure since you used the GM transmission and I will be using the Toy manual, I will have to look more closely at the VSS adaptor that NWOR offers to be sure that it is like what you are using. I got a quick look at it and now thinking back, I believe it is very much the same thing since it is listed in their GM V6/V8 conversion parts listings along with all the other adaptations for the swap. :thumbs:
4RunnerChevy
Quote from: fordh8r on September 26, 2011, 05:01:10 PM
Just make sure, its Cali legal.  Otherwise you'll go down the same road I did.  It needs an EO.  You might get lucky and the ref doesn't look for it.  I have the Downey manual if you need it, its got some info.
fordh8r
Cool! I will look into it. I'm surprised that it even mattered at all as long as it functioned like it's supposed to and keeps the CEL out. :headscratch:
4RunnerChevy
Quote from: fordh8r on September 26, 2011, 05:30:12 PM
I thought the same way.
fordh8r
#245
Nonetheless, thanks for the heads up! I will be sure to look closely for that. 8)
fordh8r
#246
Well, after some good searching, I may be leaning towards keeping the Auto trans from my donor rig. Pricing is relativley similar going either route but the VSS issue remains the same between them. I checked out the JTR site and they have some real good info on there about that subject. Thanks, again for the heads up and for turning me onto them.  :beerchug:
Are you running an electric fan or the clutch fan? You also eliminated the DRAC too, right? I know you said you used the stock exhaust, does that include the manifolds too? Any pics of this stuff from your build?
Also, what 3rds are you running...4Cyl, V6? Is your T/case a 21 or 23 Spline?
Thanks!  :bowdown:
4RunnerChevy
I am running electric fans, but the clutch fan fits fine.  I eliminated the DRAC but you can modify them for tire size, super easy, a simple jumper mod.  I am running 4 cyl thirds, with spools, and dont have a problem except for the occasional blown R&P haha (1 in four years).
If you place the motor right, the transfer case will bolt into its stock location.  No shaft mods.  I am running a 21, and one of Marlins first 4.7's, no problems. I run stock exhaust manifolds.
What exact pics are you looking for, gimme a list and I'll shoot and upload.
fordh8r
Good to know, thanks! I have 4cyl 3rds right now with a Detroit in the rear and a Soft locker in the front. Was thinking of going to 23 spline on both boxes for that added strength, just in case I should happen to 'slip' on the throttle a little. :gap: :disturbed:
fordh8r
#249
Pics of the exhaust is what I was most interested in. But anything you think may be helpful I would be most appreciative!  :biggthumpup:
4RunnerChevy
Quote from: fordh8r on September 27, 2011, 06:03:21 PM
I would go that route,  I'll take pics for you.  Gimme a few ................  then i'll post.  As far as the drac, get rid of it, cause the GM ECU takes a normal 2k signal.  If your running the Drac then you will need a 30T ring, been there if you need it.
fordh8r
Take yer time, no rush! As for the DRAC, I planned on ditching it anyway since I won't have an electronic speedo or cruise or anything else that needs a buffered signal. I'm a good ways away from all this happening so I just like to get the ball rolling in terms of research and parts acquisition before I tear apart a perfectly functional rig. I'm pretty sure that will minimize the down time. 8)
4RunnerChevy
I'll get the pics, there is not much down time cause its a pretty straight forward swap.
fordh8r
Quote from: 4runnerchevy on September 27, 2011, 06:21:50 PM
Even better! Seeing as it is my commute vehicle.  :disturbed:  I'm sure I will be at Full Tilt when the first bolts come out in hopes to get it going in possibly a weekend...but knowing me...I will end up doing a whole bunch of extra :pokinit: to make the whole conversion just THAT MUCH nicer! :willynilly:  :hammerhead:
4RunnerChevy
fordh8r
4RunnerChevy
I didn't polish the turd, but she's going on 5 years the way it sits now, I  took some skids off so you could see more. The dings on the crossover pipe have been remedied by bumpstop.  The exhaust is obviously pieced from Chevy and Napa.
fordh8r
Hahaha...no problem! I just wanted to gauge the fit of things all together so I can see how it all works as assembled. :yesnod:
4RunnerChevy
No explanation needed, just messing around
fordh8r
Hahahaha...no worries, Bro! I do appreciate all the help. :biggthumpup:
81yotalove
im guessing those are like the daystar stinger bumpstops?
81 swb 22re 35's
4RunnerChevy
Quote from: 81yotalove on October 02, 2011, 09:01:11 AM
Kinda, they are just spring stop, no oil or Nitrogen.  Its around a 400 lb spring.  I was mainly just messing around at work.  Still need to finish the mounting clamp and try and break it on a trail.
81yotalove
lol try and break it on a trail.
I dont think the daystar stinger bumps have oil or nitrogen either. they have different option of poly inserts to control how firm they are. the one you made looks nice though. its pretty cool that you have the resources and time to make one off stuff for your truck. props to you, its really cool.
81 swb 22re 35's
sckid831
the blue high steer arms in the beginning the ones you are talking about?
4RunnerChevy
4RunnerChevy
Quote from: 81yotalove on October 02, 2011, 09:58:53 AM
If it work better than my rubber, i'll have to make another.  I might try different tips, instead of UHMW, maybe rubber or urethane.
fordh8r
Pics look great! Finally had a chance to see them today.  :yupyup:  I will have to run my exhaust on the left side since I still have my stock fuel tank but I don't think that will be too difficult to make happen.  :biggthumpup:
4RunnerChevy
Quote from: fordh8r on October 02, 2011, 05:55:20 PM
I have seen people modify the crossover pipe to the otherside, but if your going smog, you will have to do that after the Cat.
4RunnerChevy
The peeps at Bobby Longs shop rocks. Any way.  New aluminum cooling & fan , winch, dual batt's, longs, all on the winter dinner table.  All ordered or received, fab under way.
4RunnerChevy
Spindle damage from last Birf failure.  Just another glitch in the install plan.  Now gotta wait for a bushing.
