Author Topic: 3rz to R bellhousing..HEARD THIS ON THE PIRATE BOARD..  (Read 2319 times)
tryn2Crawl
  • Turtle Points: 11
  • Member since Feb '05
« on: Jan 27, 2009, 12:02:44 PM »
I've heard that a tacoma 2rt( '05-up taco 4cy motor) Bellhousing  will let you bolt a "R"series tranny to a 2rz/3rz......Someone wanna chime in on this useful info?
91xcab
  • Male Posts: 48
  • Member since May '08
From what I have read the newer (96+....?) R series trans bolt up, but if you want to use an R151 turbo trans the bellhousing has to be machined down because it is too long. I plan on a 3rz swap in the future on my 91, but I still have not decided on a transmission yet.
1991 Toyota Extra Cab
  22RE
  3 in body lift - soon to be removed
  4 in Procomp IFS lift - until parts and $$$ are collected for SAS
  33" Mud Kings
  Auto to 5 speed swap COMPLETE w/ Marlin 1200lb clutch
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Mike's 80Toy
I have read also that a 2wd 1999 tacoma 2rz-fe (manuel tranny of course) bell hosuing bolts to a W56 tranny. I dont recall all the years but good to know.
Now i just need the W56. lol
Mike
tryn2Crawl [OP]
  • Turtle Points: 11
For a W series that is what everyone uses.........I'm talkin about the R series tranny bolting to the 2r/3rz..
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Back in  2000, while in the middle of my 3RZ swap, I happened to have both a W56 bellhousing and trans sitting next to a W59 bellhousing and trans. I took both bellhousings off and noticed that the pattern to the trans was the same. I immediatley called Marlin up to ask him if he thought the W59 trans was the same imput and such, and if he thought that I could use it instead of the W59. He told me to hold on and called me back about one half hour later. His response was yes, and ever since then we have all been using the W56.
Original Taco is from 95.5 to 04. and yes the W56 will bolt up to the Taco Bellhousings.
From 05 and current you have a motor called a 2TE and it is also a 2.7 but its not a 3RZ. As for it bolting up to an R sereis trans, I dont recall, but it is possible.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
wslytoy
  • Turtle Points: 36
  • Male Posts: 308
  • Member since Aug '02
It WILL work... w/ machining. The input on the older R151 and R150(88-95) is too short. Hence the reason you have to specify w/ marlin on what year R150 you're going to use HIS bellhousing on. The R150 from 95.5-04 has a tad longer input.
Last post Mar 27, 2005, 04:00:59 PM
by 88runner
Last post May 15, 2005, 09:55:04 PM
by Jared
Last post Nov 07, 2005, 12:18:25 PM
by jimbo74
Last post Jan 21, 2008, 09:16:44 AM
by EarlKann
Last post Feb 20, 2009, 04:23:54 PM
by unclejpl4x4
