Start by saying I bought my truck with alot of allready purchased parts new in boxes and bags uninstalled mostly marlin, and a couple TG parts. This part from pictures definitly looks like the TG crossmember. Everything he purchased has been dead on from 4.7 gears 23 spline, dual adapters...ETC.
Went to put my dual crossmember on today and none of the bolts line up. This is a 1991 4cyl five speed truck.
The plate kind of sits towards passenger side. Even unbolted the bolt pattern front to rear is a quarter inch to wide, And from driver side to passenger side the crossmember bolt pattern is to wide, if I bolt two of the drivers side bolts in the right holes there is no way the passenger side would fit. The inner holes would fit into the outer holes on the frame leaving the outer holes on the mount hanging off the frame. All the drain holes line up and mounts lined up.
Is it possable that I got the 79 to 83 mount by my description?
