Author Topic: W56 Interlock Pin Question  (Read 1700 times)
stahld
  • Member since Jan '09
« on: Jan 22, 2009, 01:08:38 PM »
Could someone please tell me how many interlock pins are in a 5 speed W-56 and which pins go where?  I am confused.  I have 3 pins.  I know where the long one goes; however, I have 2 shorter ones that have me confused.  They have the same length but different diameters.  Thanks!
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: W56 Interlock Pin Question
« Reply #1 on: Jan 22, 2009, 02:54:37 PM »
Long pin  5.95mm x 28.60mm between 1/2 and 3/4 shift rod
Smallest pin  3.96mm x 11.20mm in the middle bore of the 3/4 shift rod
Middle pin  5.92mm x 13.60 between 3/4 and 5/Rev rod.
It always helps to use grease to hold them in place  .
stahld [OP]
« Reply #2 on: Jan 22, 2009, 04:18:56 PM »
Thank you Marlin.
Should there be another Middle sized pin (5.92mm x 13.60) through the reverse shift head?  I am not talking about the rollpin.  Thanks again.
Marlin
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #3 on: Jan 22, 2009, 06:43:52 PM »
Yes there is, however you only asked about the three, and that is all that I measured.
You didn't think I knew this from memory now did you?
Remember to use a good quality high temp disk grease to hold the pins in place.
Marlin
Last post May 14, 2005, 11:19:49 PM
by MOB-40
Last post Jan 04, 2009, 08:07:12 AM
by 4RunnerChevy
Last post Dec 12, 2009, 05:55:49 PM
by potter85
Last post Aug 21, 2011, 01:50:16 PM
by Peterbuilt84
Last post Mar 27, 2013, 05:22:19 PM
by Bazzi
