Author Topic: Quick EGR Plug Question  (Read 979 times)
83MT
  • Turtle Points: -23
  • Member since Jun '08
« on: Jan 13, 2009, 08:48:33 AM »
Hey I know my vacuum modulator is no good right now, but my valve is functioning (not stuck open, anyways), so until I either block the system off completely or can afford to replace the vacuum modulator, I want to know if I've closed it off the right way. I pulled all the hoses going into the modulator and egr valve and plugged them. So now the vacuum hoses are plugged, but all the ports on the modulator and valve are open. Since they operate on vacuum, and my egr is closed, that's fine, right? No vacuum leak? So again the hoses are off the egr and plugged, but the ports on the egr & modulator are open. In my mind that's ok, no vacuum leak, but I wanted to make sure I don't need to plug the ports, too.
Zach
I like Yotatech
tech201
  • Male Posts: 141
  • Member since Jan '08
  • this is who we are this is what we do.
Re: Quick EGR Plug Question
« Reply #1 on: Jan 13, 2009, 07:57:40 PM »
their wont be a vacuum leak the only problem i could see depending on how long its all disconnected is stuff getting in the egr vacuum port.
83MT [OP]
« Reply #2 on: Jan 14, 2009, 07:33:51 AM »
Yeah hopefully it will only be a month or two, then I can afford to replace the modulator. Thanks!
Zach
I like Yotatech
Last post Apr 26, 2005, 05:28:21 PM
by germ
Last post Jul 02, 2005, 07:50:28 PM
by 79coyotefrg
Last post May 15, 2006, 06:06:33 PM
by Stump
Last post Sep 13, 2007, 08:49:29 AM
by Rocksurfer
Last post Dec 28, 2008, 09:46:15 PM
by THK Matt
