These are axles from a 1976 ford F150 narrowed to fit a spring over YJ! I started building them for my 1993 Wrangler but due to impending medical bills I am selling most of my toys in preperation! These axles are not complete so you would still need to buy a few parts. Final wheel pattern is 5 on 5.5
Here is what you get:
Dana 44
Narrowed to 60.5" WMS-WMS by R&P 4wd Parts (awesome guys)
Spring perches already welded on
Chevy flat top knuckles and new studs (installed by R&P)
New ball joints (installed by R&P)
New bearings and seals for both sides
New never used spindle nuts and washers
New never used Chevy spindles for both sides
New never used rotors for both sides
New never used calipers and brakes for both sides
New never used stainless braided lines
New never used warn Hubs
New never used 3.90/up carrier (used spiders)
New never used Genuine Gear 4.56 gears
Gear Master install kit (new bearings and everything, needs new pinion nut)
Caliper brackets
Sand blasted hub assembly (ford outer 5 on 5.5)
two outer stub shafts
You'll need the inner axle shafts,u-joints, hy-steer arms, drag link, and tie rod to complete this axle! You can get these parts from R&P also!
Ford 9" (big bearing)
Narrowed to 60.5" WMS-WMS by dutchman motorsports!
New never used 31 Spline axle shafts with bearings and seals
New never used Dutchman axle retaining plates
New never used Dutchman 11" brake setup
New never used genuine Gear 4.56 Gears
New never used Drums
Stock third member
the only thing you will need to finish this axle is a 31 spline carrier and weld on some spring perches! Everything I have for this axle except the third member is NEW and never Used!!!
I can produce receipts for all of these parts except maybe the gears (and i'm still looking)!
Serious inquiries only! I need to (not want to) sell these to offset the cost of upcoming medical bills, low ball offers will net no repsonse! Pictures will be posted if anyone shows interest!
PM or call/text Edward @ 503-961-4344
$2250.00 (OBO)
I would prefer not to ship!
