Ok, what I'm specifically trying to do is get the oil & volt cluster which is a separate cluster on my '83 to work. My truck did not come with one from the factory, so I'm figuring out how to wire it.
I have the electrical diagram from the FSM, but I don't really know how to read it. What I know is that each gauge (oil & volt) has 4 wires coming out of it. I gather that two are for the illumination of the gauge, and two are for the actual gauge to work. Can I assume one of each of those is a ground? Obviously I can figure out what to do with the grounds, but I have a couple other questions. First, what in the wiring diagram will tell me which is + and which is -? Second, once I know which are the +, what do I hook them into? The + for the actual oil gauge to work I will wire straight to the SR5 oil sending unit (no?). The + for the volt I wire to any hot wire? Then I need to tie my illumination + into a "key on" wire so I'm tied into the dash lights & dimmer. (right?)
So my biggest question I guess, and sorry for being such a newb, is: how exactly do I tie my +'s in to the system? I mean do I strip some plastic off a wire connected to "key on", and splice in my + wires for the illumination? If so, how do I locate that wire on my truck? How do I tell which is a "key on" wire? I know that if I knew some electrical basics this would probably be an easy thing to figure out, but I don't, so...
Last, once I get all this figured out, what gauge wires should I use?
Anyone?
