Author Topic: cooler for p/s ?  (Read 5584 times)
llamas
  • Male Posts: 142
  • Member since Sep '08
cooler for p/s ?
« on: Nov 30, 2008, 05:05:22 PM »
 is there an advantage to have a cooler on P/S?
don whitman
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
Re: cooler for p/s ?
« Reply #1 on: Nov 30, 2008, 05:09:04 PM »
Its probably only necessary of you have hydro assist or are desert racing.
Quote
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #2 on: Nov 30, 2008, 05:10:10 PM »
Most people that have coolers are running hydro asstits...the extra strain from the ram generates a lot of heat on the pump
The only advantage I can see to running a pump cooler would be increased pump life...steering pumps are cheap
...it wont do anything to increase the performance of the steering itself
Quote
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
« Reply #3 on: Nov 30, 2008, 05:56:35 PM »
I disagree, mine was a super pain to steer aired down and unlocked, I was sick of the freakin ATF overheating and blowing around the cap and jacking up the engine bay. I added a 4pass trans cooler to it and it steers better/easier and doesn't overheat anymore. Plus I got around another 1/2 quart of fluid in the system. Do it, it is cheap.
TheCookieMonster
  • Male Posts: 973
« Reply #4 on: Nov 30, 2008, 06:28:50 PM »
i just put one on my truck without hydro assist just for the cooling factor. it never hurts to have the extra fluid capacity and be able to cool it faster  :dunno:....plus their only about $10 from a junkyard  :thumbs:
also if you plan on going hydro assist you already have a cooler there
« Last Edit: Nov 30, 2008, 07:25:38 PM by TheCookieMonster »
llamas [OP]
  • Male Posts: 142
« Reply #5 on: Nov 30, 2008, 07:05:06 PM »
Well no harder to intall than a filter,       yall run filters   ??
don whitman
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Member since Feb '05
  • Mike's 80Toy
« Reply #6 on: Dec 04, 2008, 02:24:47 PM »
Filters. Never seen anyone with filters on their steering set-up.
I don't run a filter.
Mike
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #7 on: Dec 04, 2008, 02:34:47 PM »
I added a motorcycle sized filter when I flushed/replaced the fluid after 21 years of running it............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
llamas [OP]
  • Male Posts: 142
« Reply #8 on: Dec 04, 2008, 03:00:36 PM »
I put a filter on a cj i built one time cause i bought all used steering components
 and figured if i filtered a little of the crap out would be a good thing.can't hurt
don whitman
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #9 on: Dec 04, 2008, 04:17:46 PM »
I run a filter, it is built into the PSC reservoir. A cooler is a good idea on any system, stock or otherwise. The eariler Toyotas with PS came stock with one, that is what that loop on the return line in front of the radiator is.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #10 on: Dec 04, 2008, 04:30:08 PM »
i plan to run one eventually, not only will it allow more fluid, but will also cool.. some of that will be in part to more fluid, but as it is an oil, the cooler you can keep it, the better
llamas [OP]
  • Male Posts: 142
« Reply #11 on: Dec 04, 2008, 04:44:03 PM »
So the stock radiator was set up to cool the ps system?
don whitman
  • Male Posts: 8,707
« Reply #12 on: Dec 04, 2008, 04:46:08 PM »
no, the return line of the pump runs to the front of the vehicle in front of the radiator and the a/c condensor, its a metal tube that just make a sideways U shape
this is supposed to be the factory cooler
« Last Edit: Dec 04, 2008, 05:00:00 PM by jimbo74 »
llamas [OP]
  • Male Posts: 142
« Reply #13 on: Dec 04, 2008, 06:22:07 PM »
Thankyou I'll check my tomorrow , so the low pressure line goes thru that and back to
the reservoir?
don whitman
  • Male Posts: 8,707
« Reply #14 on: Dec 04, 2008, 06:31:06 PM »
oops said it was the return line, i am not actually sure which line it is
llamas [OP]
  • Male Posts: 142
« Reply #15 on: Dec 04, 2008, 07:13:03 PM »
I'm thinkin my truck doesn't have that cooler because it didn't come w/ps
 I'm putting on ps, there is a chance it might have come from the factory
 and you could get the ps option from the dealer ?
don whitman
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #16 on: Dec 04, 2008, 07:24:47 PM »
if you want one i have one. PM me if so.
  • Male Posts: 8,707
« Reply #17 on: Dec 04, 2008, 07:29:29 PM »
if you dont have power steering, you dont have that cooler, or the lines, or the power steering pump
you can probably still get everything from the dealership, but it isn't going to be cheap... it's best to find a used setup from someone who upgraded.....
llamas [OP]
  • Male Posts: 142
« Reply #18 on: Dec 04, 2008, 07:38:10 PM »
Oh I got all the parts i'm cleaning and bolting stuff on alright
 I saw a thread where somebody ask if they should put one on and
I never heard of a ps cooler so i'm just checking it out
It sounds like the right thing to do along with a filter
don whitman
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #19 on: Dec 04, 2008, 07:48:20 PM »
a cooler probably aint a bad idea...but i wouldnt worry about a filter...
just change the fluid and it should be fine...
dont forget to bleed the  PS system
Quote
OOPS
  • Male Posts: 2,561
« Reply #20 on: Dec 04, 2008, 07:57:46 PM »
You want the cooler and filter on the return line (low pressure). That is when the fluid is the hottest, after it has gone through the system and done it's work. If you put it on the high pressure side it would more then likely blow the filter apart and maybe the cooler also.
A good source for a cooler is from an 80's vintage Ford Aerostar. The cooler is located behind the front bumper. Got the one I had at P-N-P for $5.00.
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
« Reply #21 on: Dec 04, 2008, 08:02:44 PM »
I need one for my rig, i could smell it when it over heated :yikes:
TheCookieMonster
  • Male Posts: 973
« Reply #22 on: Dec 04, 2008, 11:02:09 PM »
the auto trans cooler off a newer ranger works quite well too. got one at the junkyard for $10
Last post Jan 13, 2003, 10:38:05 AM
by cruzila
Last post Apr 21, 2006, 08:48:47 AM
by abnormaltoy
Last post Nov 11, 2010, 01:51:30 PM
by R.DesJardin
Last post Oct 30, 2012, 03:57:23 PM
by 86yoter
Last post Mar 03, 2013, 07:22:51 AM
by 805_tucker
