Clamp off the soft brake hose, unbolt the hard brake lines from the rear brake cylinders, unbolt the axles from the axle housing, pop axles out of housing a couple inches, drain diff, unbolt driveline and diff and then remove diff. Just make sure you bleed the brakes good when you put it back together.
