Author Topic: socket size for the front hub assembly lock nut  (Read 2117 times)
chrisz01
  • Member since Oct '08
« on: Oct 30, 2008, 03:06:53 PM »
I am trying to buy a lock nut socket for the front hub assembly of my 85 straight front axle truck. I am getting all kinds of different sizes from different shops. Toyota said it was a 2 2/23" but I am almost sure its metric. Some say a 54mm any body know for sure? I would like to move on with the project.
chrisz01
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
its 54mm
              -Ronald Reagan
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
chrisz01 [OP]
Thanks,
chrisz01
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
You need to get a socket specially made for hub nuts.  A standard craftsman type socket has a bit of a taper before the threads start and the hub nut isn't thick enough to let it bite.
Marlin sells one here.  Its towards the bottom of the page.
http://www.marlincrawler.com/htm/axles.htm
Quote
chrisz01 [OP]
Thanks for the reply. If I would have known Marlin had the socket I would have ordered it through them, but I already ordered it through some one else. When I get closer to the project of turning the rear end into a full floater (for flat towing) I will order all the other stuff; bearings, tools, seals, etc. from Marlin crawler. There price on the 54mm socket is also lower then any body I have priced it through too. thanks for the help I am sure I will have more questions in the future.
Chrisz01
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Thats funny, I have been using a Craftsman 2 1/8 socket for over 12 years and have never had that problem. I also had one of those stamped steel ones that I loaned to someone who tried to get the nut off a bent spindle, all it did was spread it open. I had to put it in the lathe and cut it down so it would grip the nut again.
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
X2. I have the same socket in my tool box.
RynothealbinO
  • Turtle Points: -15
  • Male Posts: 141
  • Member since Aug '06
  • 36's on no lift!
When I did mine I Marlin was out of them and the only other ones I could find were impact sockets, so I just used a chisel (or a a brass bar - can't remember) to loosen and tighten my spindle nut.  It worked just fine and was definetely cheeper...although I should really get the proper socket at some point.
Trust in the LORD with all your heart and lean not on your own understanding, in all your ways acknowledge him and he will make your paths straight.  Proverbs 3:5-6  Don't let anyone look down on you because you are young, but set an example for the believers in speech, in life, in love and in purity.  1 Timothy 4:12
yota pu/runner
  • Male Posts: 208
  • Member since Apr '08
yeah same here when i did mine marlin was out also but i bought a imbact socket at sears, it worked just fine yeah having the correct tool for the job is ideal but it worked and i just haven't bought the correct one yet.
OOPS
  • Male Posts: 2,561
Why buy another when you already have one that works?
Last post Aug 01, 2004, 08:31:32 PM
by Ferg
Last post Dec 29, 2004, 12:30:02 PM
by BLACKDOG
Last post Apr 25, 2005, 09:07:17 PM
by seafarinman
Last post Aug 22, 2005, 03:19:17 PM
by Hyena
Last post Jul 09, 2007, 10:39:38 PM
by jimbo74
