Author Topic: gear box ball bearings  (Read 1061 times)
85 toy crawler
  • Member since Dec '07
« on: Oct 20, 2008, 08:13:26 AM »
Decided to tap the 87 steering box for hydro and rebuild it how do you get all the ball bearings back in any help would be great.Thanks for the help or links. :headscratch:
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re: gear box ball bearings
« Reply #1 on: Oct 20, 2008, 10:02:41 AM »
:hahaha: Too bad you didn't find the right info to start with....  On a yota box all you do is turn the input shaft all the way left and lift teh sector shaft out of the box.  That allows the worm gear setup to slide right out intact rather by taking it completely apart. :greengrin:
I have put the balls in a couple different ways, you can either pack grease coated balls into the two piece tin return tube then coat the balls in heavy sticky grease and put them in one at a time then thread the center worm into it.  Or you can take the tin tube out and feed the bass into the assembly one at a time through one of the return holes.. Thats a tricky way to do it but they both will work.
Last post Aug 04, 2004, 02:42:37 PM
by 84runner
Last post Jan 16, 2006, 11:14:52 PM
by sidewall2000
Last post Dec 20, 2007, 06:56:58 PM
by lilbuddy
Last post Feb 20, 2011, 03:01:21 PM
by TNRabbit
Last post Jan 30, 2017, 05:51:12 PM
by FZJHilux80
