Author Topic: Don't kill me..SR5 gauge swap question, just need some clarification  (Read 1094 times)
83MT
  • Turtle Points: -23
  • Member since Jun '08
Ok, here's the post on the connectors. My question is, what do these numbers represent? I need to find the Toyota diagram, figure out what these number correspond to, and pull wires out of the plugs that go into the instrument panel in my truck, and put them in the SR5 locations? Then everything will work? 'Cause now I've got an SR5 cluster with a Temp gauge that doesn't work, fuel only works sometimes, panel light doesn't work when I turn on headlights, etc. So each wire going in to the plug-in has a corresponding number, and I'll need to move the individual wires to the correct SR5 positions, instead of the non-SR5 positions they are in now? And then, assuming my new cluster is sound, things will work?
For the record, here are the pinout of SR5 vs non-SR5 gauge for 83:
SR5     non-SR5     wire color       function
 1        1            GY           Right turn signal indicator
 2
 3        3            BR (B BR)    Speed sensor (-) ground
 4        6            GL           Speed sensor (+)
 5
 6
 7        23           YG           Water temp gauge
 8        9            RW           Panel lights (+)
 9        15           YR           Fuel Gauge
10        12           Y            Ignition switched power
11        21           YB           Oil Pressure switch (idiot light)
12        22           YW           Charge (idiot light)
13        14           WB           Ground
14                                  Tach input - must be wired to igniter
                                                 yellow
15        17           GB           Left turn signal indicator
16        16           RB           Panel lights (-)
17
18
19        11           G            4WD
20
21        19           BY           Seat belt
22
23        13           RG           High Beam
24        20           GW           Brake
Zach
I like Yotatech
Last post Jun 17, 2011, 11:18:50 PM
by Fiercefirstgen559
Last post May 31, 2008, 09:39:08 PM
by T Pennington
Last post Jun 26, 2008, 01:38:25 AM
by Toymin8r
Last post Jul 08, 2008, 01:31:10 PM
by jimbo74
Last post Dec 18, 2013, 09:54:38 PM
by CruelCrawler83
