Author Topic: Q about 4.7 gear install.  (Read 1901 times)
rockcrawlinredneck
  • Turtle Points: 109
  • Male Posts: 404
  • Member since Jul '06
  • 1st Gen's rule
« on: Sep 07, 2008, 10:32:04 AM »
I just installed the 4.7's into my rear case. I greased all the surfaces like shown in the directions did not miss a step during install (that I can tell) but have a question. When it is in 2wd I can turn the input no problem, in high 4wd same thing, but when I put it into low I can not turn it by hand. Is this normal? I guess it could be the surface protectant stuff on the gears making it hard to turn. Also it is a little "stiff" so to speak to get it into low range. It goes fairly easy all the way to the neutral position but takes a little more preassure to get it into low. Any Ideas? Is this normal?
 Kevin
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Q about 4.7 gear install.
« Reply #1 on: Sep 07, 2008, 10:53:41 AM »
Absolutely not.
Quick question:
You did clearance the housing and shift fork(s), correct?
Please see: http://www.marlincrawler.com/htm/transfercase/470_clear.htm
rockcrawlinredneck [OP]
  • Male Posts: 404
  • 1st Gen's rule
« Reply #2 on: Sep 07, 2008, 11:01:09 AM »
I did clearence the bottom section of the low range box and the shift fork, but not the curly looking part of the case. I will go rip it back apart and check it. Thank you. I just got a computer back so I did the whole job with out instructions since yall dont send instructions anymore with the kit's.
 Kevin
  • Male Posts: 404
  • 1st Gen's rule
« Reply #3 on: Sep 07, 2008, 01:19:35 PM »
Problem solved. I took the low range box off and discovered that the high/low range shift rail horse shoe thing (where the roll pin holds it on) was rubbing on the new gear. I pulled it out and hit it lightly with the grider to clearence it. Works good now, I can turn the input in all the gears with no rubbing or grinding noises. Thanks for yall's help. I did not see in the directions anywhere that you had to do this, maybe my t-case is odd ball one!?!
 Kevin
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
« Reply #4 on: Sep 07, 2008, 04:00:16 PM »
that is on the instructions. Whether or not you received them is another story, but it is mentioned.
Glad you got it figured out.
  • Male Posts: 404
  • 1st Gen's rule
« Reply #5 on: Sep 07, 2008, 07:09:44 PM »
 I saw where you have to grind the 2wd/4wd block but did not see anything about the high/low block. I very well could be blind though.
 Kevin
*EDIT* I am an idiot, I went back and looked at the directions and it clicked. I ground the radius off of the other fork. I dont know how I misunderstood it but...
  • 511:1 Club
« Reply #6 on: Sep 08, 2008, 08:42:58 AM »
whooops!
Well, glad you figured it out and got it all back together!! Now get it installed and report back what you think!!
Last post Feb 01, 2006, 12:10:56 PM
by 1Bad4Runner
Last post Jun 25, 2006, 05:48:01 PM
by BigMike
Last post Dec 21, 2006, 08:34:23 PM
by notajeep
Last post Aug 28, 2007, 08:50:31 AM
by bosco
Last post Dec 08, 2010, 04:03:29 PM
by zippo
