Author Topic: question about my '85 4runner  (Read 1366 times)
toyotawheeler
  • Male Posts: 98
  • Member since Dec '07
« on: Aug 27, 2008, 05:34:06 PM »
alright i just bought an 85 4runner with a 22rec. I just replaced the timing chain and head gasket, but now it is only running on three cylinders. #1 is not firing the plug is firing and it has compression and the timing is within a few degrees, is there anything that these are known for??  Any help is greatly appreciated. Thank you.
'81 YOTA, 22R, 6IN, 63IN REARS, 4.7:1, LINCOLNS FRONT AND REAR, CUSTOM FRONT BUMPER, BUCKET SEATS, FLAT BED , SLIDERS, 37IN  MTR'S FRONT TSL REAR, CHROMOS
'85 4RUNNER, 22RE, A/T, A/C, DD, SHES A BEAST
IF YOU HIT THE BRAKES YA F***ED
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: question about my '85 4runner
« Reply #1 on: Aug 27, 2008, 05:43:56 PM »
nothing in particular..... maybe a fuel or computer problem? it all worked fine before? have you done a compression test on it?
toyotawheeler [OP]
  • Male Posts: 98
« Reply #2 on: Aug 27, 2008, 06:17:40 PM »
ya it has compression what about the wires going into the injectors? how do you check them? do i have to pull the fuel injection to get the injectors out? could the injector be clogged?
  • Male Posts: 8,707
« Reply #3 on: Aug 27, 2008, 06:20:46 PM »
could be any number of things, im thinking fuel delivery though if you have spark..... that or air deprivation...... but there is no way it aint getting air.......
what about your spark plug wires? i've had wires that would work when i tested it, but when i drove, they vibrated back apart, i had torn the inside of the wire when i changed plugs.....
i wasnt asking if you had compression, but if you had done a comrpession test? where you check the pressure in the cylinders with a gauge and see how they compare to each otehr
toyotawheeler [OP]
  • Male Posts: 98
« Reply #4 on: Aug 27, 2008, 06:23:37 PM »
no i havent checked the compression. I just do not believe it is getting fuel how do i pull the injectors? is this hard to do with the fuel injection on?
  • Male Posts: 8,707
« Reply #5 on: Aug 27, 2008, 06:32:54 PM »
you pull the fuel rail...
i would check the compression on the cylinders.......
toyotawheeler [OP]
  • Male Posts: 98
« Reply #6 on: Aug 27, 2008, 06:36:37 PM »
thanks alot i appreciate much. any other ideas welcome.
Thank you
Last post Jan 30, 2006, 10:47:59 AM
by SQUIRREL MONSTER
Last post Dec 27, 2006, 03:25:03 PM
by reklund5
Last post May 15, 2007, 04:07:27 PM
by Rocksurfer
Last post Oct 06, 2008, 10:31:10 PM
by madmax866
Last post Dec 15, 2009, 05:47:54 AM
by PA_taco_13
