This may sound stupid----- Have you removed the vacume line from the EGR valve and plugged the hose?It sounds like you are getting too much exhaust in your fuel mixture.I have found this on other trucks.Marlin
Thanks for the tips...My buddy still has the shell of the car that I robbed the parts from...I'll check and see if it had a neutral safety switch. Also, I've got whats left of the dash harness out in the shed, so I can see if I missed something. You're right about the 84 not showing a code 11- it has to have been a 85 model to have the ECU flash a code 11, right?Ryan
Have you held a timing light on it when the engine misfires to see if the timing jumps or dies? have you tried a diff distrib?
Sorry, but I just cant buy the shaved head bit.I know I have had this same problem and finally got to the cause.Now, if I can only remember-------------Searching for a good answer.Marlin in Fresno
Started by Zoomschwortz Toyota Pickup/4Runner Tech 1979-95
Started by mjos Toyota Pickup/4Runner Tech 1979-95
Started by H8PVMNT Toyota Pickup/4Runner Tech 1979-95
Started by Hurricaneinmotion Toyota Pickup/4Runner Tech 1979-95
Started by Osage1978 Engine
