Author Topic: need alot of help  (Read 2101 times)
newbe94
  • Male Posts: 80
  • Member since May '08
need alot of help
« on: Aug 16, 2008, 11:03:04 PM »
ok i have a rci fuel cell and I'm wondering if there is anyway to hook up the stock fuel gauge or do i have to buy another one
also i have fox 2.0 air shox how much oil can i put in
thanks a lot
Boosted
  • Member since Jun '08
  • PacificNWRockCrawler
Re: need alot of help
« Reply #1 on: Aug 16, 2008, 11:46:54 PM »
thanks a lot
Yes you can use the stock gauge.  Depending on the depth of your fuel cell, you might be able to mount the stock sending unit to the top of it.  I have an adjustable VDO sending unit on my RCI aluminum fuel cell and it works great.
newbe94 [OP]
  • Male Posts: 80
« Reply #2 on: Aug 17, 2008, 12:16:16 AM »
but can i use the stock wires to the cluster or will i need to buy something
Boosted
« Reply #3 on: Aug 18, 2008, 01:24:34 AM »
Yes you can use the stock wires.
newbe94 [OP]
  • Male Posts: 80
« Reply #4 on: Aug 18, 2008, 05:57:10 AM »
but i would have to use the stock sending unit or will the rci one work. if the rci one works how do i wire what wire goes were. oh i have the 15 gallon tank
thanks
Boosted
« Reply #5 on: Aug 18, 2008, 08:45:50 AM »
I didnt realize you got the fuel cell with sending unit....  That sending unit works from 0-90 ohms (Chevy style) and will not work accurately with the stock gauge.  You will need to use an after market gauge or replace the sending unit with either a stock one or an aftermarket one thats adjustable.
newbe94 [OP]
  • Male Posts: 80
« Reply #6 on: Aug 18, 2008, 07:53:51 PM »
ok thanks but do you know if the stock one will fit in the rci tank
Boosted
« Reply #7 on: Aug 18, 2008, 10:46:10 PM »
Not 100% positive, but I think it will.  You should take the stock one off and measure how tall the whole assembly is.  You may need to modify the mounting flange a little.  Before I went with the aftermarket sending unit, I actually considered using the stock one and it looked like it would work.
Hope this helps....
newbe94 [OP]
  • Male Posts: 80
« Reply #8 on: Aug 19, 2008, 03:12:05 AM »
thanks alot that helps alot  :beerchug:
Last post Apr 16, 2004, 10:00:58 PM
by Red_Runner
Last post Jul 23, 2007, 03:22:16 PM
by gtoyonrocks
Last post Jun 21, 2008, 08:40:40 PM
by Rocks For Brains
Last post Dec 16, 2008, 07:39:28 AM
by robrub00
Last post Feb 11, 2010, 07:24:19 AM
by SJyota
