Author Topic: Front axle rebuilding Q?'s  (Read 9050 times)
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« on: Aug 03, 2008, 03:01:10 PM »
I am rebuilding my front axle and was wondering what I should do with the Trunion bearings. The FSM recommends using a tool to measure for the correct shims. Since I am replacing them and there races I thought this would have to be done. Is there a DIY tool I could build or where, and how much, could I find the actual tool? Do I need to do this?
Thanks. :beerchug:
Duffil
  • *lurker*
  • Turtle Points: 88
  • Male Posts: 4,832
  • -Hack-
    • PhotoBucket
Re: Front axle rebuilding Q?'s
« Reply #1 on: Aug 03, 2008, 07:57:01 PM »
start with 1 thick and 1 thin shim, and go from there.
or just put the old ones back on.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #2 on: Aug 03, 2008, 08:07:57 PM »
I have done the one thick, one thin on both the top and the bottom of both sides, and it pulled at the higher end of the acceptable scale, about 13ish if I remember correctly. OOPS has explained it all to me before, maybe PM him if you need better answers.
OOPS
  • Online The 2.5K Group
  • Turtle Points: 895
  • Male Posts: 2,547
« Reply #3 on: Aug 03, 2008, 08:31:33 PM »
The bottom shims are how the knuckle is centered, the top ones are how the pre-load is set. Do what Duffil said as far as the bottom ones.
This place use to sell the SST but I could not find it. I even put in the PN and it did not come up. PN is 09606-60020 so they may not be making them anymore
http://toyota.spx.com/index.aspx
Your best bet is to get the "Super Seals" from Marlin. They are a lot more forgiving then the stock axle seals and well worth the extra cost.
OOPS
  • Male Posts: 2,547
« Reply #4 on: Aug 03, 2008, 08:41:24 PM »
Here is a great writeup on rebuilding the axle written in laymans terms.
http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #5 on: Aug 03, 2008, 10:37:17 PM »
"When reinstalling the steering arms and lower knuckle bearing retainers, be sure to install the appropriate shims.
I think mine were bone stock when I took them apart and there were no shims.
The rebuild kit came with a huge stack of shims. I at first put the knuckle back together w/o shims and found it was overly tight.
After asking around, the consensus seems to say 0.40mm (or 0.040" I don't know what units are used ) of shims is the right amount.
The factory manual describes a bearing drag measurement technique if you prefer:
Use a fish scale to pull on the steering arm until the break-free pull is 7-13 lbs.
Do this without the knuckle wiper seals installed, just the knuckle bearings.
Be sure to pack the knuckle bearings before installing them."
This says nothing about centering the knuckle.
And this came up for 09696-60020.
http://toyota.spx.com/detail.aspx?id=355
OOPS
  • Male Posts: 2,547
« Reply #6 on: Aug 03, 2008, 11:24:54 PM »
If you have the FSM, the real one from Toyota it talks about centering the knuckle.
If you notice when you bring up the PN there is a dash 01 after the 09696-60020. That is a different SST.
This is what the 09696-60020 looks like. I made this one on my lathe using the factory SST for measurements. The person that I borrowed it from bought it from the web page I posted.
The person that I learned to set these front ends up is a 30 year Toyota tech who is now the Foreman at the Roseville dealership.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #7 on: Aug 04, 2008, 09:40:47 AM »
Okay, that's the tool I was thinking of. So my question is, do I need to use that to center the knuckle? Do I center the knuckle or do I wing it?
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #8 on: Aug 04, 2008, 10:31:28 AM »
If using the Marlin Super Seals like I did, centering is no where near as critical as it was with just regular seals. Buy the Marlin seals and don't worry about centering it. :twocents:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #9 on: Aug 04, 2008, 10:35:12 AM »
I bought a kit from someone who said it is a Marlin kit but I can't tell.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #10 on: Aug 04, 2008, 10:53:30 AM »
I would suggest just buying the seals, because my Marlin kit did not come with the Marlin HD seals, I had to order the HD seals (MC-12149) seperately.
OOPS
  • Male Posts: 2,547
« Reply #11 on: Aug 04, 2008, 08:17:23 PM »
The Super Seals do not come with the rebuild kit you have to buy them separate.
As far a centering I would do what Duffil said, one thin one thick. I find it hard to believe that that axle has never been torn apart. I have torn apart at least twenty of them and they all had shims on the bottom trunion caps.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #12 on: Aug 04, 2008, 10:22:25 PM »
My axle is in horrible shape, leaks like a sieve. I thought the seals you were talking about were the knuckle wipers. I will buy a set of those HD seals though.
Taking apart this axle will be a first for me so I expect it all to be stock. I will go from there.
As far as tips... any for a newb?
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #13 on: Aug 04, 2008, 11:49:40 PM »
Clean. Clean everything. Before i rebuilt mine it would leave puddles of gear oil and grease because it leaked so badly. Now it doesn't leak at all. Cleaning stuff well makes just about anything easier.
Do one side at a time so if you get completely lost you can take apart the other side to see how it is supposed to work.
If you take the hub dial assembly apart, don't loose the little tiny ball bearing like I did the first time.
Umm... don't over torque anything like I did and break bolts off.
Also, on both sides of my axle, the top caliper bolt was stripped, so I did not torque them down to spec when I put it back together, I just tightened it until I felt it was about to brake loose.
Study everything on the subject you can before doing it. I read a few articles on line about it, and I read my FSM about a dozen times before tackling it.
Other than that, the only real advice I have is make sure you get those Marlin HD front axle seals.
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #14 on: Aug 05, 2008, 05:30:47 AM »
read these
http://www.birfield.com/~morgan/tech/axle/index.html
http://www.4x4wire.com/toyota/maintenance/front_end/solid_axle/
familiarize yourself with the process before you start. If you are doing a full rebuild make sure you use STOCK OEM bearings!
toyminator2000 There has to be dumb people in order for there to be smart people
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #15 on: Aug 05, 2008, 09:45:22 AM »
Well Crap.  I was going to buy the tool right after the round up to re do my front end.  Just tryied calling them and that was pointless.
Maybee I can sweet talk my local toyota parts guy into selling me one SST.  :yesnod:
I like to Drive!
OOPS
  • Male Posts: 2,547
« Reply #16 on: Aug 05, 2008, 10:35:59 PM »
I am going to throw this out and it is my opinion. Do not buy the kit from Trail Gear, the trunion bearings that come with there are no-name bearings made in China. I broke one on a wheeling trip before I got to the trail and it wiped out a 30-spline Long. I was lucky and Bobby replaced it for free. When I asked them about they told me my front-end was set-up wrong and I was the first one to every break one. They offered to send me a new kit free and I told the to keep the POS.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #17 on: Aug 05, 2008, 10:58:46 PM »
I have done quite a bit of reading now and I feel comfortable doing this job. But I still need the tools.... haha, if it isn't one thing, it's another. Tools, space, time, $$.... Oh and now I need to order the HD seals. This might take a bit longer.
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #18 on: May 01, 2010, 11:36:28 PM »
Nice article, old I know but, still a lot of good info....
  • Turtle Points: 1420
  • Male Posts: 22,623
« Reply #19 on: Mar 29, 2012, 09:15:24 PM »
I wanted to save a few pictures here since I was looking for this last weekend.
Knuckle Rebuild Kit       04434-60015       1      $92      Gaskets and shims
   Outer axle oil seal       90311-62001       2       20/pr.  Optional
   Inner axle oil seal       90311-33085       2       12/pr.  Recommended
   Steering knuckle Bearing  90366-17001-77  0-4       30/ea   Dealer or rebuild kit
   Wheel bearing, inner      90368-     -77  0-2         /ea   Aftermarket cheaper
   Wheel bearing, outer      90368-45087-77  0-2       44/ea   Aftermarket cheaper
knuckle centering sst
http://www.marlincrawler.com/hardware-tools/tools/knuckle-alignment-tool
Last post Dec 12, 2005, 05:31:03 PM
by kneedownnate
Last post Aug 27, 2007, 12:59:14 PM
by Joe S.
Last post Aug 08, 2008, 06:20:17 PM
by RCKSQRL
Last post Dec 25, 2009, 02:56:44 PM
by TOY087
Last post May 15, 2017, 05:54:54 PM
by Hickory Nut
