Author Topic: 4.3 timing issue!  (Read 2192 times)
85toyin
  • Male Posts: 21
  • Member since Apr '08
  • I need parts!
4.3 timing issue!
« on: May 10, 2008, 07:01:45 PM »
Spent the whole day today installing the harness, running some tranny lines etc....
I can't get it to start...back firing back up into the intake every once in awhile. Hold throttle open while turning over and flames arise!!
I have tried finding TDC
Lining up the marks on crank
Attempting to line up rotor button to #1
Whats next??
I'm sooo close!!
85 Toy, 4.3/700R4...work in progress
tech201
  • Male Posts: 141
  • Member since Jan '08
  • this is who we are this is what we do.
Re: 4.3 timing issue!
« Reply #1 on: May 10, 2008, 07:48:21 PM »
Is your dist cap new I've had them carbon track and cross fire and do the exact thing that your describing. oh ya the cap that does that is the flat top one that looks like it has fingers off the sides.
85toyin [OP]
  • Male Posts: 21
  • I need parts!
« Reply #2 on: May 10, 2008, 08:08:46 PM »
New plugs, wires, cap, button and dist.
tech201
  • Male Posts: 141
« Reply #3 on: May 10, 2008, 08:14:16 PM »
is it the multi port or the throttle body injection
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
« Reply #4 on: May 10, 2008, 08:16:18 PM »
Are you sure you're at tdc. Pull the number 1 plug and either look in with a flash light or use a prob so you can feel it come up. Turn the crank with a breaker bar until the piston is at the top and the timing mark is at the line. Then double check your distributer alignment.
My pulley had a couple of lines on it so it took me awhile to figure out which one was right.
85toyin [OP]
  • Male Posts: 21
  • I need parts!
« Reply #5 on: May 10, 2008, 08:18:22 PM »
TBI
85toyin [OP]
  • Male Posts: 21
  • I need parts!
« Reply #6 on: May 10, 2008, 08:21:17 PM »
I attempted to be at TDC a few different times. There are 2 marks on my crank. One is marked white and one is a simple line. I think fiding TDC is what I'm struggling on...honestly I'm not sure. 4.3 in the yota does not leave a lot of room on that side to see where the piston is. Is there a simple way to find TDC? Do the marks on the crank put you at TDC?
tech201
  • Male Posts: 141
« Reply #7 on: May 10, 2008, 08:33:47 PM »
you can use a compression gauge take the gauge off just have the hose screwed in bump the engine over when it gets to tdc youll feel the compression shoot out of the hose just go slow. thats how i do it when im not sure about the timing marks.
85toyin [OP]
  • Male Posts: 21
  • I need parts!
« Reply #8 on: May 10, 2008, 08:39:07 PM »
ok, when the hose blows out I'm at TDC and I should line the next groove to zero. When your a TDC..it is not at zero by default correct?
tech201
  • Male Posts: 141
« Reply #9 on: May 10, 2008, 08:46:59 PM »
correct this just gets you REAL close.
Last post Jan 25, 2005, 03:29:51 PM
by FATB0Y
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Feb 23, 2010, 01:32:46 PM
by axled89
Last post Oct 07, 2015, 11:33:53 AM
by 84_yota_4wd
Last post Nov 09, 2015, 07:45:46 PM
by studentwheeler
